Ok. I need some help from someone with more experience in arduino code. My goal is to get a physical button to toggle a relay (LED for testing purposes) and be able to toggle it over MQTT on a NODEMCU board
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
const char* ssid = "Co Wireless";
const char* password = "tc11141976";
const char* mqttServer = "m11.cloudmqtt.com";
const int mqttPort = 18339;
const char* mqttUser = "esp8266";
const char* mqttPassword = "esp8266";
int buttonpin = D1;
int OUTPin = D2;
int state = HIGH;
int reading;
int previous = LOW;
WiFiClient espClient;
PubSubClient client(espClient);
void setup() {
pinMode(buttonpin, INPUT);
pinMode(OUTPin, OUTPUT);
Serial.begin(115200);
digitalWrite(BUILTIN_LED, HIGH);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.println("Connecting to WiFi..");
Serial.println("Connected to the WiFi network");
client.setServer(mqttServer, mqttPort);
client.setCallback(callback);
while (!client.connected()) {
Serial.println("Connecting to MQTT...");
if (client.connect("ESP8266Client", mqttUser, mqttPassword )) {
Serial.println("connected");
} else {
Serial.print("failed with state ");
Serial.print(client.state());
delay(2000);
client.publish("esp/room/mainlight", "Roomlight is Online");
client.subscribe("esp/room/mainlight");
void reconnect() {
Serial.print("Attempting MQTT connection...");
client.publish("esp/room/mainlight", "Connected");
} else {
Serial.print("failed, rc=");
Serial.println(" try again in 5 seconds");
delay(5000);
void callback(char* topic, byte* payload, unsigned int length) {
if ((char)payload[0] == '1' && state == HIGH) {
state = LOW;
} else if ((char)payload[0] == '2' && state == LOW) {
state = HIGH;
digitalWrite(OUTPin, state);
void loop() {
if (!client.connected()) {
reconnect();
client.loop();
reading = digitalRead(buttonpin);
if (reading == HIGH && previous == LOW) {
if (state == HIGH)
state = LOW;
else
state = HIGH;
previous = reading;
delay(200);
The Button part works just fine. I cant get the MQTT to change the LED/ Relay state. I must’ve done something wrong. I think its in the void callback(char* topic, byte* payload, unsigned int length)
