Hi all!
I would like to pick some of your brains…
I have a D1 mini with a relay shield to use for my garage door as an MQTT lock. So, it sets the relay HIGH for 250ms and then LOW with both LOCK and UNLOCK functions, almost as if it is pressing the button to open or close the door.
It also then sends out a message for the state topic, so in Home Assistant it is not optimistic.
My problem is here- when the garage is door is closed physically and it shows locked in home assistant, I tell Google Assistant to close the garage door, it opens the garage door but then still shows locked in Home Assistant… and this way I am going to get house robbed very easily! Anybody got any ideas?
My code for the D1 mini is below.
Cheers!
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <Ticker.h>
#define BUTTON 0 // (Don’t Change for Sonoff)
#define RELAY D1 // (Don’t Change for Sonoff)
#define LED 13 // (Don’t Change for Sonoff)
#define MQTT_CLIENT “WeMos_D1Mini_Garage_Door_01” // mqtt client_id (Must be unique for each Sonoff)
#define MQTT_SERVER “192.168.0.1” // mqtt server
#define MQTT_PORT 1883 // mqtt port
#define MQTT_TOPIC “/Home/Garage/Door01” // mqtt topic (Must be unique for each Sonoff)
#define MQTT_USER “” // mqtt user
#define MQTT_PASS “” // mqtt password
#define WIFI_SSID “mywifi” // wifi ssid
#define WIFI_PASS “mypassword” // wifi password
#define VERSION “\n\n------------------ Sonoff Powerpoint v1.0p -------------------”
extern “C” {
#include “user_interface.h”
bool sendStatus = false;
bool requestRestart = false;
int kUpdFreq = 1;
int kRetries = 10;
unsigned long TTasks;
unsigned long count = 0;
WiFiClient wifiClient;
PubSubClient mqttClient(wifiClient, MQTT_SERVER, MQTT_PORT);
Ticker btn_timer;
void callback(const MQTT::Publish& pub) {
if (pub.payload_string() == “stat”) {
else if (pub.payload_string() == “1”) {
digitalWrite(LED, LOW);
digitalWrite(RELAY, HIGH);
delay(250);
digitalWrite(RELAY, LOW);
else if (pub.payload_string() == “0”) {
digitalWrite(LED, HIGH);
delay(250);
else if (pub.payload_string() == “reset”) {
requestRestart = true;
sendStatus = true;
void setup() {
pinMode(LED, OUTPUT);
pinMode(RELAY, OUTPUT);
pinMode(BUTTON, INPUT);
btn_timer.attach(0.05, button);
mqttClient.set_callback(callback);
WiFi.mode(WIFI_STA);
WiFi.begin(WIFI_SSID, WIFI_PASS);
Serial.begin(115200);
Serial.println(VERSION);
Serial.print("\nESP ChipID: “);
Serial.print(ESP.getChipId(), HEX);
Serial.print(”\nConnecting to “); Serial.print(WIFI_SSID); Serial.print(” Wifi");
while ((WiFi.status() != WL_CONNECTED) && kRetries --) {
delay(500);
Serial.print(" .");
if (WiFi.status() == WL_CONNECTED) {
Serial.println(" DONE");
Serial.print(“IP Address is: “); Serial.println(WiFi.localIP());
Serial.print(“Connecting to “); Serial.print(MQTT_SERVER); Serial.print(” Broker . .”);
delay(500);
while (!mqttClient.connect(MQTT::Connect(MQTT_CLIENT).set_keepalive(90).set_auth(MQTT_USER, MQTT_PASS)) && kRetries --) {
Serial.print(” .”);
delay(1000);
if (mqttClient.connected()) {
Serial.println("\n---------------------------- Logs ----------------------------");
Serial.println();
mqttClient.subscribe(MQTT_TOPIC);
blinkLED(LED, 40, 8);
else {
Serial.println(" FAILED!");
Serial.println("\n----------------------------------------------------------------");
Serial.println();
else {
Serial.println(" WiFi FAILED!");
Serial.println();
void loop() {
mqttClient.loop();
timedTasks();
checkStatus();
void blinkLED(int pin, int duration, int n) {
for (int i = 0; i < n; i++) {
digitalWrite(pin, HIGH);
delay(duration);
digitalWrite(pin, LOW);
delay(duration);
void button() {
if (!digitalRead(BUTTON)) {
count++;
else {
if (count > 1 && count <= 40) {
digitalWrite(LED, !digitalRead(LED));
delay(250);
// digitalWrite(RELAY, !digitalRead(RELAY));
sendStatus = true;
else if (count > 40) {
Serial.println("\n\nSonoff Rebooting . . . . . . . . Please Wait");
count = 0;
void checkConnection() {
Serial.println(“mqtt broker connection . . . . . . . . . . OK”);
else {
Serial.println(“mqtt broker connection . . . . . . . . . . LOST”);
else {
Serial.println(“WiFi connection . . . . . . . . . . LOST”);
void checkStatus() {
if (sendStatus) {
if (digitalRead(LED) == LOW) {
mqttClient.publish(MQTT::Publish(MQTT_TOPIC"/stat", “1”).set_retain().set_qos(1));
Serial.println(“Relay . . . . . . . . . . . . . . . . . . ON”);
} else {
mqttClient.publish(MQTT::Publish(MQTT_TOPIC"/stat", “0”).set_retain().set_qos(1));
Serial.println(“Relay . . . . . . . . . . . . . . . . . . OFF”);
sendStatus = false;
if (requestRestart) {
blinkLED(LED, 400, 4);
ESP.restart();
void timedTasks() {
if ((millis() > TTasks + (kUpdFreq * 60000)) || (millis() < TTasks)) {
TTasks = millis();
checkConnection();
