I have a sonoff sv running tasmota 5.14 connected to an electric monitored Strike.
Im using GPIO 04 as switch 1 (possibly to help with state of lock)
and GPIO 14 as switch 2 set up as binary sensor to tell if the door is closed(working well)
What i cant get to work is have the state of the lock report back to home assistant via mqtt.
This only shows the state unlocked (padlock pic is unlocked) hence only showing the lock button
below is the status of tasmota on the sonoff sv
11:00:56 MQT: stat/frontdoor/STATUS = {“Status”:{“Module”:3,“FriendlyName”:[“Front Door”],“Topic”:“frontdoor”,“ButtonTopic”:“frontdoor”,“Power”:0,“PowerOnState”:1,“LedState”:1,“SaveData”:1,“SaveState”:1,“ButtonRetain”:0,“PowerRetain”:1}}
11:00:56 MQT: stat/frontdoor/STATUS1 = {“StatusPRM”:{“Baudrate”:115200,“GroupTopic”:“Entry”,“OtaUrl”:“http://sonoff.maddox.co.uk/tasmota/sonoff.bin",“RestartReason”:"Software/System restart”,“Uptime”:“7T08:32:45”,“StartupUTC”:“2019-07-21T01:28:11”,“Sleep”:0,“BootCount”:142,“SaveCount”:419,“SaveAddress”:“F4000”}}
11:00:56 MQT: stat/frontdoor/STATUS2 = {“StatusFWR”:{“Version”:“5.14.0”,“BuildDateTime”:“2018-07-23T16:44:37”,“Boot”:31,“Core”:“2_3_0”,“SDK”:“1.5.3(aec24ac9)”}}
11:00:56 MQT: stat/frontdoor/STATUS3 = {“StatusLOG”:{“SerialLog”:2,“WebLog”:2,“SysLog”:0,“LogHost”:"",“LogPort”:514,“SSId”:[“FortKnox”,""],“TelePeriod”:10,“SetOption”:[“000080A9”,“55818000”]}}
11:00:56 MQT: stat/frontdoor/STATUS4 = {“StatusMEM”:{“ProgramSize”:528,“Free”:472,“Heap”:18,“ProgramFlashSize”:1024,“FlashSize”:1024,“FlashMode”:3}}
11:00:56 MQT: stat/frontdoor/STATUS5 = {“StatusNET”:{“Hostname”:“frontdoor-4817”,“IPAddress”:“192.168.1.135”,“Gateway”:“192.168.1.1”,“Subnetmask”:“255.255.255.0”,“DNSServer”:“192.168.1.1”,“Mac”:“DC:4F:22:4B:72:D1”,“Webserver”:2,“WifiConfig”:2}}
11:00:56 MQT: stat/frontdoor/STATUS6 = {“StatusMQT”:{“MqttHost”:“192.168.1.48”,“MqttPort”:1883,“MqttClientMask”:“DVES_%06X”,“MqttClient”:“DVES_4B72D1”,“MqttUser”:“DEVuser”,“MqttType”:1,“MAX_PACKET_SIZE”:1000,“KEEPALIVE”:15}}
11:00:56 MQT: stat/frontdoor/STATUS7 = {“StatusTIM”:{“UTC”:“Sun Jul 28 10:00:56 2019”,“Local”:“Sun Jul 28 11:00:56 2019”,“StartDST”:“Sun Mar 31 02:00:00 2019”,“EndDST”:“Sun Oct 27 03:00:00 2019”,“Timezone”:1,“Sunrise”:“05:18”,“Sunset”:“20:35”}}
11:00:56 MQT: stat/frontdoor/STATUS10 = {“StatusSNS”:{“Time”:“2019-07-28T11:00:56”,“Switch1”:“OFF”,“Switch2”:“ON”}}
11:00:56 MQT: stat/frontdoor/STATUS11 = {“StatusSTS”:{“Time”:“2019-07-28T11:00:56”,“Uptime”:“7T08:32:45”,“Vcc”:3.156,“POWER”:“ON”,“Wifi”:{“AP”:1,“SSId”:“FortKnox”,“RSSI”:78,“APMac”:“F0:9F:C2:67:0F:17”}}}
11:01:05 MQT: tele/frontdoor/STATE = {“Time”:“2019-07-28T11:01:05”,“Uptime”:“7T08:32:54”,“Vcc”:3.156,“POWER”:“ON”,“Wifi”:{“AP”:1,“SSId”:“FortKnox”,“RSSI”:84,“APMac”:“F0:9F:C2:67:0F:17”}}
11:01:05 MQT: tele/frontdoor/SENSOR = {“Time”:“2019-07-28T11:01:05”,“Switch1”:“OFF”,“Switch2”:“ON”}
This is my Hassio Config
lock:
- platform: mqtt
state_topic: "cmnd/door/POWER1"
value_template: "{{ value_json.Locked }}"
command_topic: "cmnd/frontdoor/POWER"
payload_unlock: "1"
payload_lock: "0"
qos: 1
binary_sensor:
- platform: mqtt
state_topic: "cmnd/door/POWER2"
device_class: door
payload_on: "OFF"
payload_off: "ON"
Any help would be greatly appreciated
