Hi
I recently updated to core_2023.7.3.
Since then, any Tasmota lights/switches are unavailable.
I think I have tracked it down to MQTT:
In HA log:
Failed to connect to MQTT server due to exception: [Errno 111] Connection refused
In Mosquitto broker log there seems to be a looping restart:
[15:17:41] INFO: Starting mosquitto MQTT broker...
2023-08-04 15:17:41: Warning: Mosquitto should not be run as root/administrator.
[15:17:41] INFO: Successfully send discovery information to Home Assistant.
[03:17:41] INFO: Service restart after closing
[15:17:41] INFO: Successfully send service information to the Supervisor.
[15:17:42] INFO: Starting mosquitto MQTT broker...
2023-08-04 15:17:42: Warning: Mosquitto should not be run as root/administrator.
[15:17:42] INFO: Successfully send discovery information to Home Assistant.
[15:17:42] INFO: Successfully send service information to the Supervisor.
[03:17:42] INFO: Service restart after closing
[15:17:43] INFO: Starting mosquitto MQTT broker...
2023-08-04 15:17:43: Warning: Mosquitto should not be run as root/administrator.
[15:17:43] INFO: Successfully send discovery information to Home Assistant.
[03:17:43] INFO: Service restart after closing
[15:17:43] INFO: Successfully send service information to the Supervisor.
[15:17:44] INFO: Starting mosquitto MQTT broker...
2023-08-04 15:17:44: Warning: Mosquitto should not be run as root/administrator.
... and on it goes....
The I tried the add-on with the watchdog turned off, but still the same, which I thought odd.
Add-on is 6.2.1.
What other relevant info can I supply that would be helpful to track this down?
The fam is upset 'cos the lights aren’t working!
Everything was working just fine till the core update.
Thanks!!
Edit - the add-on’s CPU usage seems very high too - about 20% on an Intel NUC??
