Mqtt Manual Alarm - HIGH PRIORITY!
Hi home assistant guys. I realise that (using retain:true) after reboot Home Assistant the alarm state goes to disamr and doens’t retain if it was armed before reboot. By the other hand if I don’t use retain=true after reboot the alarm state goes to arm and doesn’t retain if it was disarmed before reboot.
Any solution to this issue? This is my code (I’m using Hassio):
alarm_control_panel:
  • platform: manual_mqtt
    state_topic: home/alarm
    command_topic: home/alarm/set
    retain: true
    pending_time: 10
    delay_time: 20
    trigger_time: 4
    disarmed:
    trigger_time: 0
    armed_home:
    pending_time: 0
    delay_time: 0
Did you ever find an answer?
Seems to be fixed with the latest version of hassio. Regards.
