After the last update, I tried to update my alarm panel to use some of the new parameters listed in the MQTT Manual Alarm Panel documentation. However, I consistently receive configuration errors for some of the new params.
The following params are not allowed:
- code_arm_required
- arming_time
- command_template
- code_arm_required
- code_disarm_required
- code_template
The error thrown in the Configuration validation is as follows:
Invalid config for [alarm_control_panel.manual_mqtt]: [arming_time] is an invalid option for [alarm_control_panel.manual_mqtt].
Check: alarm_control_panel.manual_mqtt->arming_time. (See ?, line ?).
Also, after the latest update, I would expect the Manual MQTT (Alarm Panel) to share the same configuration and params as the Manual (Alarm Panel). This was mentioned as a breaking change in the recent release of Home Assistant 0.110, yet those changes for the Manual Alarm Panel are not reflected in the documentation for the MQTT Manual Alarm Panel. It’s a bit confusing since the MQTT Manual is based on the Manual.
It also appears in one you have a command_template
, but in the other you have a code_template
, and also pending_time
vs arming_time
I would expect that I could do this in my configuration file for the platform manual_mqtt
alarm_control_panel:
- platform: manual_mqtt
state_topic: home/alarm
command_topic: home/alarm/set
trigger_time: 1800
disarm_after_trigger: false
delay_time: 30
arming_time: 60
command_template: "{\"action\":\"{{action}}\",\"code\":\"{{code}}\"}"
code_arm_required: false
code_disarm_required: true
code: 1234
Has anyone encountered this issue and perhaps knows if this is just a temporary oversight in the documentation? I am the maintainer of an open source MQTT Alarm Panel for Android based on the MQTT Manual Alarm Panel, so it would be nice to use some of these new updates such as the command template and arming and disarming states.
Thanks!
