MQTT message does not trigger automation on first attempt
Hi! I have a sonoff rf bridge running tasmota/portish that receives 433 and sends mqtt to home assistant. Its used to trigger some motion sensors and some extra smokedetectors, watersensors etc. It use to work perfect with almost instant triggering of automations in HA. But for some time now it stopped triggering automations on first attempt… but it triggers on “second attempt”.Ex: I see the motion sensor trigger, but nothing happens. I wait 30 sec, trigger sensor again and then light turns on. Ive been searching for topics on subject but I have no luck so far. Im no HA wizzard so this might be a simple soulotion I prehaps should have figured out, but still after 5+ years with HA I still strugle with wrapping my head around it all… I also have notification set upp to my mobile device and its has become increasably longer delaytime from automation triggering to notification received… about 2 minutes sometimes…
Thanks for any help! :grinning:
Ole
On what type computer are you running HA on, and what kind of installation ?
Thank you for replying! Im running HA on a raspberry pi4 with ssd. Core
2024.2.3
Supervisor
2024.03.0
Operating System
12.0
Frontend
20240207.1
A pi4 should not have such long delays. Are you running CPU-intensive tasks/add-ons ? How much free memory ?
only 4.3% used storage… 201 GB free data. Its probably separate issues. But it seems like mqtt goes in to a sleep mode and needs a command to wake up. I might be wrong. I can see in tasmota console that the sonoff bridge is receiving data and I can see the topic received in home assistant / mqtt settings / listen to topic… no automation when triggering for about 30 sek and after that automation triggers instantly on triggering… Seems like a sleep setting i dont know about in mqtt/HA…
That is HDD space, I was talking about RAM memory.
Of corse, sorry… it look to be between 47-48 %, 0.9 of 2 GB.
