I am trying to integrate sensor data from rtl_433, which can provide MQTT messages from a large range of wireless weather sensors, thermometers etc. HASS currently assumes (AFAIK) that messages from each sensor is nicely divided into separate topics. Unfortunately that is not the case for rtl_433, where the topic value contains a JSON string including the type and ID of the sensor.
e.g.
home/rtl_433 {“time” : “2018-02-11 15:03:07”, “model” : “Fine Offset Electronics, WH25”, “id” : 229, “temperature_C” : 21.100, “humidity” : 29, “pressure” : 977.500}
Therefore it would be nice to have the possibility to further filter messages based on the payload of the message with a template:
filter_template
(template)(Optional)Defines a template to filter messages based on payload content.
Template must resolve to the boolean value true for the message to be decoded.
Default value: {{ true }}
Yes, that is what I currently do. However it becomes very unwieldy with many sensors with multiple values. Furthermore it will trigger a state update, even though it was not the right sensor.
I have tried to make a proof of concept implementation that works well for me. If it has general interest, I am happy to submit a pull request (including documentation update) https://github.com/vestom/home-assistant/tree/mqtt_filter
/Tommy
Yeah, but it is not quite my problem. The issue is having messages from different sensors with same topic, where the sensor is identified by a payload value.
I sorted this by changing the rtl_433 script so it checks the model field of the json package and then submits to a different topic, and in HA the sensors read from the different topics if that makes sense.
I also needed a RBE block to filter repetitive commands, I’m receiving from 433MHz remotes and keeping the button down repeats the transmission too many times.
Nonetheless, I’m really interested in seeing @jchasey solution. Can you post the rtl_433 script, or just the changes you made?
/usr/local/bin/rtl_433 -F json $PROTOCOL | while read line
do
# We don't know from the output which protocol number was received
# However we can extract the device name from json output
DEVICE="$(echo $line | jq --raw-output '.model')"
if [ "$DEVICE" = "HIDEKI TS04 sensor" ]; then
MQTT_TOPIC="home/rtl433/weather"
fi
if [ "$DEVICE" = "Oil watchman" ]; then
MQTT_TOPIC="home/rtl433/oil"
fi
# Publish the json to the appropriate topic
echo $line | /usr/bin/mosquitto_pub -h $MQTT_HOST -u $MQTT_USER -P $MQTT_PASS -i RTL_433 -r -l -t $MQTT_TOPIC
done
