MQTT mosquito connected with result code 5
Can you help a newbie please?
I have installed MosquitoMQTT broker and enabled newly added entity using the system options.
I have installed add-on for Sofar Solar and set the mqtt_host to be the ip address of my home assistant with mqtt_port 1883. I am not seeing the Sofar in HA. In the log I am seeing these messages every 2 minutes:
INFO [MqttClient] Connected with result code 5
WARNING [MqttClient] Unexpected MQTT disconnection. Will auto-reconnect
