I’ve been struggling for a while now to add the xiaomi sensor temp/humid/pressure (WSDCGQ11LM).
As far as I can see it is paired with the zigbee2mqtt addon and seem to be recognized with mosquitto but I cant find it in the states.
Help would be much appreciated!
z2m log:
zigbee2mqtt:info 8/23/2019, 9:27:17 AM MQTT publish: topic 'homeassistant/sensor/0x00158d00036b4d73/linkquality/config', payload '{"unit_of_measurement":"-","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/xiaomi_test","json_attributes_topic":"zigbee2mqtt/xiaomi_test","name":"xiaomi_test_linkquality","unique_id":"0x00158d00036b4d73_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00158d00036b4d73"],"name":"xiaomi_test","sw_version":"Zigbee2mqtt 1.5.1","model":"Aqara temperature, humidity and pressure sensor (WSDCGQ11LM)","manufacturer":"Xiaomi"},"availability_topic":"zigbee2mqtt/bridge/state"}'
mosquitto log:
[09:27:14] INFO: Setup mosquitto configuration
[09:27:15] INFO: No local user available
[09:27:15] INFO: Initialize Hass.io Add-on services
[09:27:15] INFO: Initialize Home Assistant discovery
[09:27:15] INFO: Start Mosquitto daemon
1566541635: Loading config file /share/mosquitto/acl.conf
1566541635: mosquitto version 1.6.3 starting
1566541635: Config loaded from /etc/mosquitto.conf.
1566541635: Loading plugin: /usr/share/mosquitto/auth-plug.so
1566541635: |-- *** auth-plug: startup
1566541635: ├── Username/password checking enabled.
1566541635: ├── TLS-PSK checking enabled.
1566541635: └── Extended authentication not enabled.
1566541635: Opening ipv4 listen socket on port 1883.
1566541635: Opening ipv6 listen socket on port 1883.
1566541635: Opening websockets listen socket on port 1884.
1566541635: Opening ipv4 listen socket on port 8883.
1566541635: Opening ipv6 listen socket on port 8883.
1566541635: Opening websockets listen socket on port 8884.
1566541635: Warning: Mosquitto should not be run as root/administrator.
1566541635: New connection from 172.30.33.4 on port 1883.
[INFO] found USER on Home Assistant
1566541637: New client connected from 172.30.33.4 as mqttjs_e56dd359 (p2, c1, k60, u'valna').
