"logins": [
{"username": "local-user", "password": "mypw"}
"anonymous": false,
"customize": {
"active": false,
"folder": "mosquitto"
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
Is this going to my config.ymal?
i have the add on, i have made a new user, but cant find
*3.Once back on-line, return to Configuration > Integrations and select configure next to MQTT.*
i i get is: This integration has no devices
regard
I iam unsure if it work, i have now add the new folder
and on nr 3: its user [YOUR_MQTT_USER] is i dont have any sholde i put my ip to rpi?
i have trying to send a test, dont know if i did i right: i did go to:
Call Service” and then write: mqtt/mqtt_send
and trying to send ````
“topic”:“home-assistant/switch/1/on”,
“payload”:“Switch is ON”
get this back: Failed to call service mqtt/mqtt_send/null. expected str for dictionary value @ data['service']. Got None
I have been thinking, maybe my mtqq brokener on rpi, is working, but the link above, in NOT installd in anyway, i thinkging i need to installt it to my RPI, but i dont know how, i am using hassio on rpi
i think i maybe have done right now, now i just need to see is working or not. first i need to ask smothing, when i start the mqtt broker i get this:1564849290: Warning: Mosquitto should not be run as root/administrator
i have a user on HA, but i think its reding the admin and not the user, any tips?
and i have sent lots of messenger, dot get any error, but cant sems to resvice them, i have using mqttfx and mqtt explorer and terminal, but dot get any:(
