Hi everyone,
I’m very new to the Home Assistant system and not really experienced with coding etc. The initial setup of the system is done but I had some problems with Mosquitto MQTT. I want to use it to connect my solar inverter (via OpenDTU) with HA to visualize energy production etc.
I did the setup according an easy manual from the internet. Install Add-on, create user for mqtt, restart HA, look at integrations for automatically detected mqtt integration. But it does not detect it. Manually adding using “core-mosquitto” etc. does not work.
Looking at the Logfile when starting the add-on gives the following error (see screenshot):
Does anyone know how to solve this problem and to make it work? Sorry I’m a bit newbie and would need some easy description and a step by step manual;)
Thank you all!
