I have moved across from home assistant to Hassio.
I have a used the built-in hassio mqqt broker, installed successfully and locally connected to it.
However none of my remote devices connect to it, none of them have user name and password, and tbh by the time I learn about that, they were already inaccessible
Is there anything else I need to provide, or does anyone know what silly mistake i have made?
a switch for example is:
- platform: mqtt
name: "Flood Light Switch"
state_topic: "switch/boys/floods"
command_topic: "switch/boys/floods"
payload_on: "ON"
payload_off: "OFF"
state_on: "ON"
state_off: "OFF"
optimistic: false
retain: true
and a sensor is
- platform: mqtt
name: Landing Temperature
state_topic: "Landing/temp"
unit_of_measurement: 'Ā°C'
device_class: temperature
my original set up was Home Assistant, MQTT and node-red operating in Docker containers.
I was then moving the entire set up across to hassio, so copied across all flows, and copied across the home assistant config files across to hassio and set up the MQTT broker on hassio.
I have not changed any of the configurations, so no name changes etc.
i can connect to the broker using MQTTBox, and shows as connected in the MQTT log:
1574894092: New connection from 192.168.1.107 on port 1883.
1574894092: New client connected from 192.168.1.107 as 4a906583-97c9-4664-ac3f-115313f00a381574894092786 (p2, c1, k10)
but it will not receive or send data to the broker, or atlest but publish and subscribing to the same topic, i do not get a response when sending.
Many thanks
