I have a NodeMCU with 10 DS18B20 temperature sensors attached. They send their values over MQTT to Mosquitto. All sensors are set up exactly the same way. When I check the output in MQTT Explorer I get the values for all 10 sensors, as expected.
Mosquitto (in my Home Assistant) receives 8 out of 10 values. So the values for 2 sensors are dropped. When I listen to the topic in the Mosquitto settings it stays quiet for these 2 sensors, even though they do show up in my MQTT Explorer program. There are no errors in the log files. In fact, they even show up in the Home Assistant log file (see below)!
The issue is with sensor vvw_av1 and sensor vvw_rt4. The rest of them are working flawlessly.
I can understand if NONE of my sensors would show up: that would probably be a configuration error on my part. But 2 out of 10, even though they’re set up the same way and are working? I’ve tried to delete them in ESPeasy, set them up again, with a different name, but to no avail. I don’t get it…
My configuration.yaml:
mqtt:
discovery: true
discovery_prefix: homeassistant
birth_message:
topic: 'hass/status'
payload: 'online'
will_message:
payload: 'offline'
#Vloerverwarming sensoren
- platform: mqtt
state_topic: ESP_Easy_vvw/vvw_av1/temperature
- platform: mqtt
state_topic: ESP_Easy_vvw/vvw_av2/temperature
- platform: mqtt
state_topic: ESP_Easy_vvw/vvw_av3/temperature
- platform: mqtt
state_topic: ESP_Easy_vvw/vvw_av4/temperature
- platform: mqtt
state_topic: ESP_Easy_vvw/vvw_av5/temperature
- platform: mqtt
state_topic: ESP_Easy_vvw/vvw_rt1/temperature
- platform: mqtt
state_topic: ESP_Easy_vvw/vvw_rt2/temperature
- platform: mqtt
state_topic: ESP_Easy_vvw/vvw_rt3/temperature
- platform: mqtt
state_topic: ESP_Easy_vvw/vvw_rt4/temperature
- platform: mqtt
state_topic: ESP_Easy_vvw/vvw_rt5/temperature
Home Assistant log:
2021-02-02 12:29:36 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/ESP_Easy_vvw/vvw_av3/temperature (retained): b'22.00'
2021-02-02 12:29:36 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/ESP_Easy_vvw/vvw_rt5/temperature (retained): b'22.00'
2021-02-02 12:29:36 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/ESP_Easy_vvw/vvw_rt3/temperature (retained): b'22.00'
2021-02-02 12:29:36 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/ESP_Easy_vvw/vvw_av4/temperature (retained): b'22.00'
2021-02-02 12:29:36 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/ESP_Easy_vvw/vvw_rt1/temperature (retained): b'21.75'
2021-02-02 12:29:36 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/ESP_Easy_vvw/vvw_rt2/temperature (retained): b'22.00'
2021-02-02 12:29:36 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/ESP_Easy_vvw/vvw_av2/temperature (retained): b'21.75'
2021-02-02 12:29:36 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/ESP_Easy_vvw/vvw_av5/temperature (retained): b'22.00'
2021-02-02 12:29:36 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/ESP_Easy_vvw/vvw_rt4/temperature (retained): b'22.00'
2021-02-02 12:29:36 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on homeassistant/ESP_Easy_vvw/vvw_av1/temperature (retained): b'21.50'
