Even after a fresh/clean install of python & ha I get this:
2017-07-02 11:04:53 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "C:\Python36\lib\asyncio\tasks.py", line 179, in _step
result = coro.send(None)
File "C:\Users\Halfluck\AppData\Roaming\.homeassistant\deps\hbmqtt\broker.py", line 336, in stream_connected
yield from self.client_connected(listener_name, StreamReaderAdapter(reader), StreamWriterAdapter(writer))
File "C:\Users\Halfluck\AppData\Roaming\.homeassistant\deps\hbmqtt\broker.py", line 469, in client_connected
yield from self.publish_retained_messages_for_subscription(subscription, client_session)
File "C:\Users\Halfluck\AppData\Roaming\.homeassistant\deps\hbmqtt\broker.py", line 719, in publish_retained_messages_for_subscription
handler.mqtt_publish(
AttributeError: 'NoneType' object has no attribute 'mqtt_publish'
I have the same issue; using the embedded MQTT broker:
2017-07-01 20:40:22 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.4/asyncio/tasks.py", line 237, in _step
result = next(coro)
File "/home/homeassistant/.homeassistant/deps/hbmqtt/broker.py", line 336, in stream_connected
File "/home/homeassistant/.homeassistant/deps/hbmqtt/broker.py", line 469, in client_connected
File "/home/homeassistant/.homeassistant/deps/hbmqtt/broker.py", line 719, in publish_retained_messages_for_subscription
I am using the embedded broker as well and did NOT have tls_insecure: True line in my configuration. Getting the same error messages as @buzzeddesign:
2017-07-02 23:49:52 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
result = next(coro)
configuration.yaml has no additional attributes or settings:
from my configuration.yaml file all I have for mqtt is:
# Enable MQTT server mqtt:
However, my situation is more severe in that the UI is also not starting. There’s also nothing in the log file. So it seems like HA isn’t starting at all.
If I look at the processes running I see some unusual activity: homeass+ 1352 1 0 21:24 ? 00:00:06 /srv/homeassistant/homeassistant_venv/bin/python3 /srv/homeassistant/homeassistant_venv/bin/hass -c /home/homeassistant/.homeassistant homeass+ 1369 1352 0 21:24 ? 00:00:02 /srv/homeassistant/homeassistant_venv/bin/python3 -m pip install --quiet paho-mqtt==1.3.0 --upgrade --target /home/homeassistant/.homeassistant/deps --constraint /srv/homeassistant/homeassistant_venv/lib/python3.4/site-pac postgres 1371 619 0 21:24 ? 00:00:00 postgres: homeassistant homeassistant [local] idle homeass+ 1377 1369 0 21:24 ? 00:00:04 /srv/homeassistant/homeassistant_venv/bin/python3 -c import setuptools, tokenize;__file__='/tmp/pip-build-tz5j4v8k/paho-mqtt/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close
I don’t think I should be seeing the paho-mqtt install sitting there. I wonder if that is blocking HA from starting.
I also don’t recognize the python3 import setuptools process. I’ve not seen that before. Should that be there?
Anyway, I’ll keep poking around to see what’s going on. I hope this provides a clue.
OK. I rebooted HA a few times and waited. Now the UI starts, but I still don’t have MQTT working. Like the others stated, there’s nothing in the logs about MQTT either.
