I’ve used the AIO-installer on several occasions without any problems. This time, the MQTT-broker did not install so I need to do it manually. Is it possible to retrieve the exact steps taken when installing mosquitto from the AIO-installer?
Tried to compile mqtt manually and it didn’t work due to some library missing. Ran sudo apt-get install libwebsockets-dev, which allowed me to compile.
Next problem to solve is getting mqtt auto starting (I can run it manually.)
Same problems for me. I’m trying a clean install but now I’ve read this I don’t like my chances. I was able to install mosquitto separately but it didn’t accept any connections.
Did you create a user and password file after installing? I did that and started mosquitto using “mosquitto -d”. It works, but mosquitto is not started automatically.
