I installed the add-on, set anonymous and active to true
, but Home Assistant can’t connect to it.
I also did the ACL instructions, but without the user
line before the topic
one, because, what user if I want to have it anonymous?!
The wemos can successfully send messages to it, as I verified with MQTT Explorer.
When I go to Developer Tools > MQTT > Listen to a topic
and start listening to the topic I use, nothing happens and I get this error in Developer Tools > Logs
Error handling message: Unknown error
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 20, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/mqtt/__init__.py", line 1251, in websocket_subscribe
hass, msg["topic"], forward_messages
File "/usr/src/homeassistant/homeassistant/components/mqtt/__init__.py", line 442, in async_subscribe
encoding,
File "/usr/src/homeassistant/homeassistant/components/mqtt/__init__.py", line 842, in async_subscribe
await self._async_perform_subscription(topic, qos)
File "/usr/src/homeassistant/homeassistant/components/mqtt/__init__.py", line 878, in _async_perform_subscription
_raise_on_error(result)
File "/usr/src/homeassistant/homeassistant/components/mqtt/__init__.py", line 985, in _raise_on_error
"Error talking to MQTT: {}".format(mqtt.error_string(result_code))
homeassistant.exceptions.HomeAssistantError: Error talking to MQTT: The client is not currently connected.
