Hi!
Try my project, Mqtt-np — a web-based MQTT client.
It can connect to both cloud and local brokers via the WSS protocol. For local brokers, just add the certificate to your browser storage.
You can view logs or create widgets from topics. The app also supports Google authentication and synchronization across your devices.
As it is it appears to have limited relation to Home Assistant, at least maybe HAOS.
I would suggest perhaps provide some examples on set-up and use with Home Assistant specifically otherwise it’s a bit off topic.
If you use zigbee2mqtt or other automation that sends data through an MQTT broker, I think this will be useful for you for debugging and data monitoring.
Hello everyone! I've posted the app binaries for Android, Windows, and Linux on the releases page. You can download them to explore a wider range of MQTT-NP capabilities.
