Using the MQTT number integration for some configurable parameters in my heating system (set points etc for Nibe heat pump via NibePi). It’s fantastic to no longer need helper automations in the background for set/get of values, but unlike input_number it’s not possible to set mode of slider/box. The slider takes up a lot of space and it’s hard to make a precise input when the steps are small
I was disappointed that NibePi did not allow the RW registers to be changed from within HA. I assumed it would right out the box like zigbee2mqtt.
From your request (which I upvoted) I understand that you made it possible to update your Nibe using MQTT number. I will look into that . Thanks!!
Would you mind sharing your code for this? I have been searching for this a long time. I was about to switch to nibeGW. I guess this info will benefit more people.
I like te look of you screen. Is it possible to share the complete code for this? I’am very curios how you configured the dropdown menu with the heatpump mode (Auto). Thanks in advance!
