I’m using the code below to control my central heating system.
Everything works fine, except the fact that the hot water production is allways on.
Could anyone help me adapting the code so I can switch on and off the hot water production over mqtt.
This example runs directly on ESP8266 chip.
Please be sure to select the right ESP8266 module
in the Tools -> Board -> WeMos D1 Mini
Adjust settings in Config.h before run
#include <ESP8266WiFi.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <PubSubClient.h>
#include <OpenTherm.h>
// Your WiFi credentials.
// Set password to "" for open networks.
const char* ssid = "YOUR_WIFI";
const char* pass = "YOUR_PASSWORD";
// Your MQTT broker address and credentials
const char* mqtt_server = "xxx.xxx.xxx.xxx";
const char* mqtt_user = "mqtt_user";
const char* mqtt_password = "mqtt_password";
const int mqtt_port = 1883;
// Master OpenTherm Shield pins configuration
const int OT_IN_PIN = 4; //for Arduino, 4 for ESP8266 (D2), 21 for ESP32
const int OT_OUT_PIN = 5; //for Arduino, 5 for ESP8266 (D1), 22 for ESP32
// Temperature sensor pin
const int ROOM_TEMP_SENSOR_PIN = 14; //for Arduino, 14 for ESP8266 (D5), 18 for ESP32
// MQTT topics
const char* CURRENT_TEMP_GET_TOPIC = "opentherm-thermostat/current-temperature/get";
const char* CURRENT_TEMP_SET_TOPIC = "opentherm-thermostat/current-temperature/set";
const char* TEMP_SETPOINT_GET_TOPIC = "opentherm-thermostat/setpoint-temperature/get";
const char* TEMP_SETPOINT_SET_TOPIC = "opentherm-thermostat/setpoint-temperature/set";
const char* MODE_GET_TOPIC = "opentherm-thermostat/mode/get";
const char* MODE_SET_TOPIC = "opentherm-thermostat/mode/set";
const char* TEMP_BOILER_GET_TOPIC = "opentherm-thermostat/boiler-temperature/get";
const char* TEMP_BOILER_TARGET_GET_TOPIC = "opentherm-thermostat/boiler-target-temperature/get";
const unsigned long extTempTimeout_ms = 60 * 1000;
const unsigned long statusUpdateInterval_ms = 1000;
float sp = 15, //set point
t = 15, //current temperature
t_last = 0, //prior temperature
ierr = 25, //integral error
dt = 0, //time between measurements
op = 0; //PID controller output
unsigned long ts = 0, new_ts = 0; //timestamp
unsigned long lastUpdate = 0;
unsigned long lastTempSet = 0;
bool heatingEnabled = true;
#define MSG_BUFFER_SIZE (50)
char msg[MSG_BUFFER_SIZE];
OneWire oneWire(ROOM_TEMP_SENSOR_PIN);
DallasTemperature sensors(&oneWire);
OpenTherm ot(OT_IN_PIN, OT_OUT_PIN);
WiFiClient espClient;
PubSubClient client(espClient);
void ICACHE_RAM_ATTR handleInterrupt() {
ot.handleInterrupt();
float getTemp() {
unsigned long now = millis();
if (now - lastTempSet > extTempTimeout_ms)
return sensors.getTempCByIndex(0);
else
return t;
float pid(float sp, float pv, float pv_last, float& ierr, float dt) {
float KP = 10;
float KI = 0.02;
// upper and lower bounds on heater level
float ophi = 63;
float oplo = 20;
// calculate the error
float error = sp - pv;
// calculate the integral error
ierr = ierr + KI * error * dt;
// calculate the measurement derivative
//float dpv = (pv - pv_last) / dt;
// calculate the PID output
float P = KP * error; //proportional contribution
float I = ierr; //integral contribution
float op = P + I;
// implement anti-reset windup
if ((op < oplo) || (op > ophi)) {
I = I - KI * error * dt;
// clip output
op = max(oplo, min(ophi, op));
ierr = I;
Serial.println("sp=" + String(sp) + " pv=" + String(pv) + " dt=" + String(dt) + " op=" + String(op) + " P=" + String(P) + " I=" + String(I));
return op;
// This function calculates temperature and sends data to MQTT every second.
void updateData()
//Set/Get Boiler Status
bool enableHotWater = true;
bool enableCooling = false;
unsigned long response = ot.setBoilerStatus(heatingEnabled, enableHotWater, enableCooling);
OpenThermResponseStatus responseStatus = ot.getLastResponseStatus();
if (responseStatus != OpenThermResponseStatus::SUCCESS) {
Serial.println("Error: Invalid boiler response " + String(response, HEX));
t = getTemp();
new_ts = millis();
dt = (new_ts - ts) / 1000.0;
ts = new_ts;
if (responseStatus == OpenThermResponseStatus::SUCCESS) {
op = pid(sp, t, t_last, ierr, dt);
ot.setBoilerTemperature(op);
t_last = t;
sensors.requestTemperatures(); //async temperature request
snprintf (msg, MSG_BUFFER_SIZE, "%s", String(op).c_str());
client.publish(TEMP_BOILER_TARGET_GET_TOPIC, msg);
snprintf (msg, MSG_BUFFER_SIZE, "%s", String(t).c_str());
client.publish(CURRENT_TEMP_GET_TOPIC, msg);
float bt = ot.getBoilerTemperature();
snprintf (msg, MSG_BUFFER_SIZE, "%s", String(bt).c_str());
client.publish(TEMP_BOILER_GET_TOPIC, msg);
snprintf (msg, MSG_BUFFER_SIZE, "%s", String(sp).c_str());
client.publish(TEMP_SETPOINT_GET_TOPIC, msg);
snprintf (msg, MSG_BUFFER_SIZE, "%s", heatingEnabled ? "heat" : "off");
client.publish(MODE_GET_TOPIC, msg);
Serial.print("Current temperature: " + String(t) + " °C ");
String tempSource = (millis() - lastTempSet > extTempTimeout_ms)
? "(internal sensor)"
: "(external sensor)";
Serial.println(tempSource);
String convertPayloadToStr(byte* payload, unsigned int length) {
char s[length + 1];
s[length] = 0;
for (int i = 0; i < length; ++i)
s[i] = payload[i];
String tempRequestStr(s);
return tempRequestStr;
const String setpointSetTopic(TEMP_SETPOINT_SET_TOPIC);
const String currentTempSetTopic(CURRENT_TEMP_SET_TOPIC);
const String modeSetTopic(MODE_SET_TOPIC);
void callback(char* topic, byte* payload, unsigned int length) {
const String topicStr(topic);
String payloadStr = convertPayloadToStr(payload, length);
if (topicStr == setpointSetTopic) {
Serial.println("Set target temperature: " + payloadStr);
sp = payloadStr.toFloat();
else if (topicStr == currentTempSetTopic) {
t = payloadStr.toFloat();
lastTempSet = millis();
else if (topicStr == modeSetTopic) {
Serial.println("Set mode: " + payloadStr);
if (payloadStr == "heat")
else if (payloadStr == "off")
heatingEnabled = false;
else
Serial.println("Unknown mode");
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
const char* clientId = "opentherm-thermostat-test";
if (client.connect(clientId, mqtt_user, mqtt_password)) {
Serial.println("ok");
client.subscribe(TEMP_SETPOINT_SET_TOPIC);
client.subscribe(MODE_SET_TOPIC);
client.subscribe(CURRENT_TEMP_SET_TOPIC);
} else {
Serial.print(" failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void setup()
Serial.begin(115200);
Serial.println("Connecting to " + String(ssid));
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, pass);
int deadCounter = 20;
while (WiFi.status() != WL_CONNECTED && deadCounter-- > 0) {
delay(500);
Serial.print(".");
if (WiFi.status() != WL_CONNECTED) {
Serial.println("Failed to connect to " + String(ssid));
while (true);
else {
client.setServer(mqtt_server, mqtt_port);
client.setCallback(callback);
ot.begin(handleInterrupt);
//Init DS18B20 sensor
sensors.begin();
sensors.setWaitForConversion(false); //switch to async mode
t, t_last = sensors.getTempCByIndex(0);
ts = millis();
lastTempSet = -extTempTimeout_ms;
void loop()
if (!client.connected()) {
reconnect();
client.loop();
if (now - lastUpdate > statusUpdateInterval_ms) {
lastUpdate = now;
updateData();
