MQTT parsing help
I know this is an old thread that I started but I’m updating it so it’s all in one place. I ended up adding to this script after playing around with @andrewjfreyer monitor script here:
I learned a lot playing around with this tool but unfortunately it wasn’t reliable enough for my use-case whereas my original script which I adapted from @Bit-River original script which was used to detect my tiles was. I’ve since updated my script to include my phone and my wife’s phone via Bluetooth.
His original script is here:
I had to pair the phones to my BT dongle on my Linux server (after hunting down and installing the Linux Broadcom firmware for it but it’s easy to find as it’s a BCM20702A)
[1478751.487994] usb 2-1.5: Product: BCM20702A0
[1478751.487999] usb 2-1.5: Manufacturer: Broadcom Corp
[1478751.488003] usb 2-1.5: SerialNumber: 5CF370891ECD
[1478751.598430] Bluetooth: hci0: BCM: chip id 63
[1478751.599345] Bluetooth: hci0: BCM: features 0x07
[1478751.615276] Bluetooth: hci0: BCM20702A
[1478751.616433] Bluetooth: hci0: BCM20702A1 (001.002.014) build 0000
[1478752.169121] bluetooth hci0: firmware: direct-loading firmware brcm/BCM20702A1-0b05-17cb.hcd
[1478753.038470] Bluetooth: hci0: BCM20702A1 (001.002.014) build 1347
[1478753.055441] Bluetooth: hci0: Broadcom Bluetooth Device
https://www.amazon.ca/ASUS-USB-Adapter-Bluetooth-USB-BT400/dp/B00DJ83070
In order to pair, I executed the following to pair the dongle to each phone:
hcitool cc 00:00:00:00:00:00
hcitool auth 00:00:00:00:00:00
hcitool dc 00:00:00:00:00:00
Just replace 00:00:00:00:00:00 with the BT MAC address of your phone. On my wife’s iPhone I was at the home screen/desktop whereas on my Android (Oreo) I was in Bluetooth settings. In both cases, the devices asked me to pair to my Linux server with the dongle (device shows up as host name of the server.)
Here’s the updated script:
import paho.mqtt.publish as publish
import paho.mqtt.client as mqtt
import bluetooth
from bluepy.btle import Scanner, DefaultDelegate
from random import randint
from time import sleep
mqtt_host = 'mqtt_ip_addr'
mqtt_port = 1883
mqtt_clid = 'blescan'
mqtt_auth = {
  'username':"mqtt_username",
  'password':"mqtt_password"
bt_macs = [ 'xx:xx:xx:xx:xx:xx', 'yy:yy:yy:yy:yy:yy' ]
class ScanDelegate(DefaultDelegate):
    def __init__(self):
        DefaultDelegate.__init__(self)
    def handleDiscovery(self, dev, isNewDev, isNewData):
        return()
scanner = Scanner().withDelegate(ScanDelegate())
while True:
  devices = scanner.scan()
  for dev in devices:
    publish.single(mqtt_clid + '/' + dev.addr,
      payload=1,
      hostname=mqtt_host,
      client_id=mqtt_clid,
      auth=mqtt_auth,
      port=mqtt_port,
      protocol=mqtt.MQTTv311)
  for bdaddr in bt_macs:
    btdev = bluetooth.lookup_name(bdaddr)
    if btdev is not None:
      publish.single(mqtt_clid + '/' + bdaddr,
        payload=1,
        hostname=mqtt_host,
        auth=mqtt_auth,
        port=mqtt_port,
  sleep(randint(30,60))
Just replace the MAC addresses in bt_macs with the MAC addresses of your devices to be scanned (not BTLE devices; these are picked up on the first part of the scan and injected into MQTT automatically) I’ve since adapted to a binary sensor to track these from MQTT and no longer doing any transform as I mentioned above originally. Script will write 1/on to the topic and the sensor will auto-set to 0/off after 90 seconds. There is a randomized 30-60 sleep period between each scan attempt.
binary_sensor:
  - platform: mqtt
    state_topic: "blescan/zz:zz:zz:zz:zz:zz"
    payload_on: 1
    off_delay: 90
    qos: 0
  - platform: mqtt
    state_topic: "blescan/yy:yy:yy:yy:yy:yy"
    payload_on: 1
    off_delay: 90
    qos: 0
I run this from /etc/rc.local:
hciconfig hci0 down
hciconfig hci0 up
/usr/bin/python3.5 /home/hass/homeassistant/ble_scan.py &
Which I control via systemctl as a service (/etc/systemd/system/rc-local.service):
[Unit]
 Description=/etc/rc.local Compatibility
 ConditionPathExists=/etc/rc.local
[Service]
 Type=forking
 ExecStart=/etc/rc.local start
 RemainAfterExit=no
 Restart=on-failure
 RestartSec=5s
[Install]
 WantedBy=multi-user.target
