So I’m trying to integrate my brewpiless into hass, it’s a small software running on a esp that takes care of a fridge dedicated for fermentation.
The software supports mqtt control (BrewPiLess/doc/MQTT.md at 690eb0edcefc2d700dd84755dd2a4b74d770dff7 · vitotai/BrewPiLess · GitHub) and I’ve made the input sliders for temperatures but I want to be able to set the mode:
Mode
The values can be 0,1,2,3 or o,f,b,p for ‘Off’, ‘Fridge Constant’, ‘Beer Constant’, and ‘Beer Profile’. If the mode is changed to ‘Beer Profile’, the current profile will be used and the profile starting time will be set to current time. That is, you should edit the profile beforehand, and expect the profile to be execute starting from the time it is set.
So I’ve made a input select like this:
input_select:
fridge_mode:
options:
- 'Off'
- 'Fridge constant'
- 'Beer constant'
- 'Beer profile'
icon: mdi:beer
And then an automation with a payload template:
- alias: Set fridge mode
platform: state
entity_id: input_select.fridge_mode
- service: mqtt.publish
data_template:
topic: "/brewing/modeSet"
payload_template: >-
{% if states('input_select.fridge_mode', 'off') %}
o
{% elif states('input_select.fridge_mode', 'Fridge constant') %}
f
{% elif states('input_select.fridge_mode', 'Beer constant') %}
b
{% elif states('input_select.fridge_mode', 'Beer profile') %}
p
{% else %}
b
{% endif %}
but I just keep getting the following error:
Error while executing automation automation.set_fridge_mode. Unknown error for call_service at pos 1:
File "/usr/src/homeassistant/homeassistant/components/automation/__init__.py", line 397, in async_trigger
await self.action_script.async_run(variables, trigger_context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 247, in async_run
await self._handle_action(action, variables, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 331, in _handle_action
await self._actions[_determine_action(action)](action, variables, context)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 413, in _async_call_service
context=context,
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 86, in async_call_from_config
template.render_complex(config[CONF_SERVICE_DATA_TEMPLATE], variables)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 70, in render_complex
return {key: render_complex(item, variables) for key, item in value.items()}
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 70, in <dictcomp>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 72, in render_complex
return value.async_render(variables)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 221, in async_render
return compiled.render(kwargs).strip()
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 1090, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 832, in handle_exception
reraise(*rewrite_traceback_stack(source=source))
File "/usr/local/lib/python3.7/site-packages/jinja2/_compat.py", line 28, in reraise
raise value.with_traceback(tb)
File "<template>", line 1, in top-level template code
File "/usr/local/lib/python3.7/site-packages/jinja2/sandbox.py", line 462, in call
return __context.call(__obj, *args, **kwargs)
TypeError: __call__() takes 2 positional arguments but 3 were given
