MQTT platform: mapping values are not allowed here
I have some topics which I would like to read from my mosquitto server. Looking at the mosquitto log I can see:
1557567396: Received PUBLISH from 1694498882 (d0, q0, r1, m0, '1694xxxxx2.V', ... (6 bytes))
1557567396: Received PUBLISH from 1694498882 (d0, q0, r1, m0, '1694xxxxx2.A', ... (4 bytes))
1557567396: Received PUBLISH from 1694498882 (d0, q0, r1, m0, '1694xxxxx2.W', ... (3 bytes))
1557567396: Received PUBLISH from 1694498882 (d0, q0, r1, m0, '1694xxxxx2.Wh', ... (4 bytes))
1557567396: Received PUBLISH from 1694498882 (d0, q0, r1, m0, '1694xxxxx2.KWh', ... (3 bytes))
1557567396: Received PUBLISH from 1694498882 (d0, q0, r1, m0, '1694xxxxx2.PF', ... (4 bytes))
1557567396: Received PUBLISH from 1694498882 (d0, q0, r1, m0, '1694xxxxx2.Temp', ... (2 bytes))
1557567396: Received PUBLISH from 1694498882 (d0, q0, r1, m0, '1694xxxxx2.OUT', ... (1 bytes))
1557567396: Received PUBLISH from 1694498882 (d0, q0, r1, m0, '1694xxxxx2.JSON', ... (77 bytes))
So I wrote a piece of configuration in my conf subfile: /config/sensors/smart-mac.yaml:
- platform: mqtt
   state_topic: '1694xxxxx2.V'
   unit_of_measurement: 'V'
- platform: mqtt
   state_topic: '1694xxxxx2.A'
   unit_of_measurement: 'A'
- platform: mqtt
   state_topic: '1694xxxxx2.W'
   unit_of_measurement: 'W'
- platform: mqtt
   state_topic: '1694xxxxx2.PF'
Unfortunately when I check the configuration inside Homeassistant I got the error:
Error loading /config/configuration.yaml: mapping values are not allowed here in “/config/sensors/smart-mac.yaml”, line 2, column 15
What is wrong?
spacing issue
should be
- platform: mqtt
You are right, wrong indent or space issue :sweat_smile:
Thank You for your support
similar problem but indenting seem fine to me:
  – platform: mqtt
    state_topic: "shellies/shellyEM-D3B312/emeter/0/reactive_power"
    unit_of_measurement: "VAR"
    icon: mdi:speedometer
any idea?
