Hi
Trying to sort out MQTT switch that keeps turning off. Its a Medion smart plug with Tasmota 8.2.0.6 loaded, setoption19 on and this randomly triggers power off:
08:40:05 WIF: Checking connection...
08:40:21 MQT: Received Topic "cmnd/medion1/POWER", Data Size 2, Data "ON"
08:40:21 SRC: MQTT
08:40:21 CMD: Group 0, Index 1, Command "POWER", Data "ON"
08:40:21 MQT: tele/medion1/STATE = {"Time":"2020-05-06T08:40:21","Uptime":"0T00:56:06","UptimeSec":3366,"Heap":16,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"ON","Wifi":{"AP":1,"SSId":"Telstra11CE_2GEXT","BSSId":"A0:63:91:DB:EF:2B","Channel":10,"RSSI":100,"Signal":-33,"LinkCount":1,"Downtime":"0T00:00:03"}}
08:40:21 MQT: stat/medion1/RESULT = {"POWER":"ON"}
08:40:21 MQT: stat/medion1/POWER = ON (retained)
08:40:21 CFG: Saved to flash at F8, Count 100, Bytes 4096
08:40:23 MQT: tele/medion1/HASS_STATE = {"Version":"8.2.0.6(fb2b29e-tasmota)","BuildDateTime":"2020-05-05T10:01:20","Core":"2_7_0","SDK":"2.2.2-dev(38a443e)","Module":"Medion","RestartReason":"Software/System restart","Uptime":"0T00:56:08","WiFi LinkCount":1,"WiFi Downtime":"0T00:00:03","MqttCount":1,"BootCount":7,"SaveCount":100,"IPAddress":"192.168.0.130","RSSI":"100","LoadAvg":19}
08:40:25 WIF: Checking connection...
08:40:45 WIF: Checking connection...
08:41:05 WIF: Checking connection...
08:41:25 WIF: Checking connection...
08:41:45 WIF: Checking connection...
08:42:05 WIF: Checking connection...
08:42:06 APP: Button1 immediate
08:42:06 MQT: stat/medion1/BUTTON1T = {"TRIG":""}
08:42:06 SRC: Button
08:42:06 MQT: tele/medion1/STATE = {"Time":"2020-05-06T08:42:06","Uptime":"0T00:57:51","UptimeSec":3471,"Heap":16,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Telstra11CE_2GEXT","BSSId":"A0:63:91:DB:EF:2B","Channel":10,"RSSI":100,"Signal":-32,"LinkCount":1,"Downtime":"0T00:00:03"}}
08:42:06 MQT: stat/medion1/RESULT = {"POWER":"OFF"}
08:42:06 MQT: stat/medion1/POWER = OFF (retained)
08:42:06 CFG: Saved to flash at F7, Count 101, Bytes 4096
08:42:25 WIF: Checking connection...
Tasmota status:
08:49:41 CMD: status 0
08:49:41 SRC: WebConsole from 192.168.0.81
08:49:41 CMD: Group 0, Index 1, Command "STATUS", Data "0"
08:49:41 MQT: stat/medion1/STATUS = {"Status":{"Module":0,"FriendlyName":["medion1"],"Topic":"medion1","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":1,"LedMask":"FFFF","SaveData":1,"SaveState":1,"SwitchTopic":"0","SwitchMode":[0,0,0,0,0,0,0,0],"ButtonRetain":0,"SwitchRetain":0,"SensorRetain":0,"PowerRetain":1}}
08:49:41 MQT: stat/medion1/STATUS1 = {"StatusPRM":{"Baudrate":115200,"SerialConfig":"8N1","GroupTopic":"tasmotas","OtaUrl":"http://thehackbox.org/tasmota/release/tasmota.bin","RestartReason":"Software/System restart","Uptime":"0T01:05:26","StartupUTC":"2020-05-05T21:44:15","Sleep":50,"CfgHolder":4617,"BootCount":7,"BCResetTime":"2020-05-05T10:10:47","SaveCount":101,"SaveAddress":"F7000"}}
08:49:41 MQT: stat/medion1/STATUS2 = {"StatusFWR":{"Version":"8.2.0.6(fb2b29e-tasmota)","BuildDateTime":"2020-05-05T10:01:20","Boot":4,"Core":"2_7_0","SDK":"2.2.2-dev(38a443e)","Hardware":"ESP8285","CR":"409/699"}}
08:49:41 MQT: stat/medion1/STATUS3 = {"StatusLOG":{"SerialLog":4,"WebLog":4,"MqttLog":4,"SysLog":4,"LogHost":"192.168.0.1","LogPort":514,"SSId":["Telstra11CE_2GEXT","Cecil"],"TelePeriod":300,"Resolution":"558180C0","SetOption":["000AA029","2805C8000100060000005A00000000000000","00000200","00000000"]}}
08:49:41 MQT: stat/medion1/STATUS4 = {"StatusMEM":{"ProgramSize":585,"Free":416,"Heap":22,"ProgramFlashSize":1024,"FlashSize":1024,"FlashChipId":"144051","FlashMode":3,"Features":["00000809","8FDAE797","043683A0","000000CD","010013C0","C000F981","00000024"],"Drivers":"1,2,3,4,5,6,7,8,9,10,12,16,18,19,20,21,22,24,26,27,29,30,35,37","Sensors":"1,2,3,4,5,6"}}
08:49:41 MQT: stat/medion1/STATUS5 = {"StatusNET":{"Hostname":"medion1-1129","IPAddress":"192.168.0.130","Gateway":"192.168.0.1","Subnetmask":"255.255.255.0","DNSServer":"192.168.0.3","Mac":"84:0D:8E:4C:84:69","Webserver":2,"WifiConfig":4,"WifiPower":17.0}}
08:49:41 MQT: stat/medion1/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.0.17","MqttPort":1883,"MqttClientMask":"DVES_%06X","MqttClient":"DVES_4C8469","MqttUser":"airoguard","MqttCount":1,"MAX_PACKET_SIZE":1200,"KEEPALIVE":30}}
08:49:41 MQT: stat/medion1/STATUS7 = {"StatusTIM":{"UTC":"2020-05-05T22:49:41","Local":"2020-05-06T08:49:41","StartDST":"2020-10-04T03:00:00","EndDST":"2020-04-05T02:00:00","Timezone":99,"Sunrise":"14:20","Sunset":"05:13"}}
08:49:41 MQT: stat/medion1/STATUS9 = {"StatusPTH":{"PowerDelta":0,"PowerLow":0,"PowerHigh":0,"VoltageLow":0,"VoltageHigh":0,"CurrentLow":0,"CurrentHigh":0}}
08:49:41 MQT: stat/medion1/STATUS10 = {"StatusSNS":{"Time":"2020-05-06T08:49:41","ENERGY":{"TotalStartTime":"2020-05-05T10:10:47","Total":0.071,"Yesterday":0.000,"Today":0.071,"Power":0,"ApparentPower":0,"ReactivePower":0,"Factor":0.00,"Voltage":0,"Current":0.000}}}
08:49:41 MQT: stat/medion1/STATUS11 = {"StatusSTS":{"Time":"2020-05-06T08:49:41","Uptime":"0T01:05:26","UptimeSec":3926,"Heap":21,"SleepMode":"Dynamic","Sleep":50,"LoadAvg":19,"MqttCount":1,"POWER":"OFF","Wifi":{"AP":1,"SSId":"Telstra11CE_2GEXT","BSSId":"A0:63:91:DB:EF:2B","Channel":10,"RSSI":100,"Signal":-37,"LinkCount":1,"Downtime":"0T00:00:03"}}}
I note that setoption19 on is not swapping prefix and topic in tasmota? Is this normal?
Is this faulty hardware or faulty config? This device is cheap and nasty.
Rob
