Not sure if this is a HA problem or not. but giving me major problems
Just purchased a Odroid N2+ to replace the Odroid XU4
in Configuration.yaml:-
mqtt:
broker: 192.168.1.154
port: 1883
client_id: home-assistant
username: None
password: None
- platform: time_date
display_options:
- 'time'
- 'date'
- 'date_time'
# - 'date_time_iso'
# - 'time_date'
# - 'time_utc'
- 'beat'
# - platform: state
# entity_id: sensor.time
- platform: moon
- platform: mqtt
name: "Hot Water Temp"
state_topic: "/iot4/IOT4SH01DS_A03625/temperature"
unit_of_measurement: "C"
- platform: mqtt
state_topic: "shellies/shellyem-109664/emeter/0/energy"
value_template: "{{ value|float / 60000 }}" # Fix for Watt-minutes
qos: 1
unit_of_measurement: "kWh"
# icon: mdi:chart-bar
- platform: mqtt
state_topic: "shellies/shellyem-109664/emeter/0/power"
# value_template: "{{ value|float / 1000 }}" # Fix for inverter/em sensor
qos: 1
unit_of_measurement: "W"
switch:
name: Hot Water Boiler
state_topic: "/iot4/IOT4SH01RELAY_D341DE/relay/0"
command_topic: "/iot4/IOT4SH01RELAY_D341DE/relay/0/set"
payload_on: "1"
payload_off: "0"
- platform: mqtt
name: Solar Hot Water
state_topic: "stat/evilbox1/POWER"
command_topic: "cmnd/evilbox1/POWER"
payload_on: "ON"
payload_off: "OFF"
- platform: mqtt
state_topic: "stat/evilbox2/POWER"
command_topic: "cmnd/evilbox2/POWER"
payload_on: "ON"
payload_off: "OFF"
- platform: mqtt
state_topic: "shellies/shellyem-109664/relay/0"
command_topic: "shellies/shellyem-109664/relay/0/command"
payload_on: "on"
payload_off: "off"
- platform: mqtt
state_topic: "shellies/shelly1-24D7A3/relay/0"
command_topic: "shellies/shelly1-24D7A3/relay/0/command"
payload_on: "on"
payload_off: "off"
- platform: mqtt
state_topic: "shellies/shelly1-24D64E/relay/0"
command_topic: "shellies/shelly1-24D64E/relay/0/command"
payload_on: "on"
```, mosquitto and mosquitto-clients are loaded and running
OS is Ubuntu 20.04LTS
here is the strange bit
If I point from the MQTT integration at the old XU4 on 192.168.1.82:1883, the devices show in lovelace, but water temp is flashing between unavailable and a reading.
Using MQTT Explorer on the old XU4 at xx.xx.xx.82:1883 devices are shown.
BUT
on the N2+ on xx.xx.xx.154:1883 no devices are shown, the mosquitto directory has been copied from one machine to the other so the config file is the same as before.
From MQTT Explorer test.mosquitto.org is functional.
HA companion on my mobile phone is showing the same as lovelace, so the networking through the router looks OK.
any ideas why the devices that talk to the broker on the XU4 wont talk to the broker on the N2.
As most are wired directly to the mains , I'll try powering the whole house down , in case they are still trying to look for xx.xx.xx.82 , the old XU4..
suggestions appreciated, thanks
