Hi there,
just got MQTT now configured with SSL. i’ve been using it for a while to receive data, but now i’m looking to publish data out in a specific XML format that another system parses. I’ve done some manual tests in MQTT explorer and the built in MQTT publish a packet section and everything checks out there.
now i’m trying to figure out how to get this to work over the mqtt.publish service.
if i send this message through the MQTT configure section in the payload, it works fine, but is it possible to send this in the payload_template of the mqtt.publish? the Dev tools section doesn’t seem to allow the XML. anyone have thoughts?
<MainMetaData xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<SensorList>
<!--Data can be sent for many sensors -->
<SensorMetaData>
<!-- a list of data is provided per sensor -->
<MetaDataList>
<MetaData>
<!-- the key for this metadata -->
<Key>person_detected</Key>
<!-- the value for this metadata -->
<Value>true</Value>
</MetaData>
</MetaDataList>
<Id>1</Id>
<!-- ISO 8601 format date/time of the metadata for this sensor -->
<Timestamp>{{ now().timestamp() | timestamp_custom('%Y-%m-%dT%H:%M:%S') } </Timestamp>
</SensorMetaData>
</SensorList>
</MainMetaData>
