Hello! I’m trying to set the color (to full red) of an internal RGB light of an android tablet. I use the following code but It does not work. All commands should be in JSON format according to the tablet MQTT API documentation
I only use MQTT with zigbee through zigbee2mqtt, so I am not sure if it applies to you, but the topic goes without quotes in yaml. Also, numeric values often go without quotes too. In your example "11665424" could be 11665424. I am pasting a piece of my format, which works, but again I am not sure if this applies to you. Perhaps you can experiment with the syntax based on it?
