Ive a problem sending this payload via the Automation GUI or using the “Configurator” Add-on
If test-drive the message through the MQTT in configurations everything works but if I paste it in the automation payload it does not work. Ive narrow it down to " {{ states.sensor.dolar_ccl_venta.state }} "
Example: working message (Tested using the MQTT publisher in settings):
Hi all,
I want to use my Awitrix with Home Assistant,
MQTT was actived on Awtrix and connection OK to HA.
MQTT integation on HA is OK
But when I use service mqtt.publish on developper tools, no answer from awtrix.
Can you confirm how publish an corect simple message ?
Where can I check log of send message ?
