intelka
(Andree)
November 26, 2024, 9:53am
1
Hi guys,
I want to send via mqtt.publish automation the minimum and maximum temperature for today, and week.
I tried using the code mentioned in the thread by @vingerha : Extracting values from weather.forecast_home
It does show the maximum but not the minimum temperature
The user @Troon said this no longer applies and I should open a new post
Here is my automation YAML code:
service: mqtt.publish
topic: homeassistant/sensor/IntelkaSW-8e8c-3/datetime
payload: |-
"datetime": "{{ now().timestamp() | timestamp_custom("%Y-%d-%mT%H:%M:%S%z") }}",
"weather": "{{ states('weather.forecast_home') }}",
"temperature": "{{ state_attr('weather.forecast_home','temperature') }}",
"humidity": "{{ state_attr('weather.forecast_home','humidity') }}",
"max_temperature": "{{ state_attr('weather.forecast_home','forecast') | selectattr('datetime', 'search', now().timestamp() | timestamp_custom('%Y-%m-%d')) | map(attribute='temperature') | max }}",
"min_temperature": "{{ state_attr('weather.forecast_home','forecast') | selectattr('datetime', 'search', now().timestamp() | timestamp_custom('%Y-%m-%d')) | map(attribute='temperature') | min }}"
Output:
"datetime": "2024-26-11T10:50:00+0100",
"weather": "rainy",
"temperature": "7.9",
"humidity": "77",
"max_temperature": 8.3
"min_temperature": 8.3
Please let me know why minimum is not working and what should I do to fix this in my automation YAML code.
Thanks and regards
Andree
Troon
(Troon)
November 26, 2024, 11:42am
2
I said that the old code in that thread no longer applies, as the method of getting forecast data has changed.
Please put this into Developer Tools / Template and paste the full result here:
{{ state_attr('weather.forecast_home','forecast') }}
intelka
(Andree)
November 27, 2024, 7:35am
3
Hi @Troon ,
I updated my HomeAssistant to the latest version:
Core - 2024.11.3
Supervisor - 2024.11.4
Frontend - 20241106.2
This made my code not work at all now. (All information coming from forecast)
After that I went to Developer Tools and pasted the command you shared and got null
Result
Result type: dict
null
This template listens for the following state changed events:
Entity : weather.forecast_home
Thanks in advance and appreciate your help
Kindly, please advise.
Andree
Troon
(Troon)
November 27, 2024, 9:57am
4
Take a look at the first example here:
That should create a template sensor that contains the forecast data from your weather provider. You can then use that to work out the lowest temperatures.
intelka
(Andree)
November 27, 2024, 10:13am
5
Hi @Troon ,
I tried the code mentioned in the developer tools templates section, my entity is weather.forecast_home
Here the adjusted code:
template:
- trigger:
- trigger: time_pattern
hours: /1
- action: weather.get_forecasts
type: hourly
entity_id: weather.forecast_home
response_variable: hourly
- name: Temperature forecast next hour
unique_id: temperature_forecast_next_hour
state: "{{ hourly['weather.forecast_home'].forecast[0].temperature }}"
unit_of_measurement: °C
but got as result:
UndefinedError: 'hourly' is undefined
Not sure if I’m creating the template in the correct place. What am I missing?
Thanks and regards
Andree
Troon
(Troon)
November 27, 2024, 10:17am
6
You’re not. The template editor is merely for trying out Jinja templates.
This is YAML configuration and needs to be in configuration.yaml
. I realise it starts with template:
but this code is not a template in itself. Only the bit in {{...}}
is a template.
Please add a couple of lines to it, so you get this at the end:
attributes:
forecast: "{{ hourly['weather.forecast_home'].forecast }}"
That way, the sensor will have the current temperature as its state, and the whole forecast in an attribute.
intelka
(Andree)
November 27, 2024, 12:20pm
7
Hi @Troon ,
Okay, I moved this change to my configuration.yaml file and added the lines you mentioned at the bottom. Here’s the updated code snippet
template:
- trigger:
hours: /1
type: hourly
attributes:
I left it running for a couple of hours (since it runs once an hour) and when I looked at the Developer Tools → States → Entity : sensor.temperature_forecast_next_hour
The State shows as unknown
and attributes as unit_of_measurement: °C friendly_name: Temperature forecast next hour
But cannot see any of the attributes for forecasts. Not sure what may be causing issues now.
Thanks and regards
Andree
Troon
(Troon)
November 27, 2024, 1:25pm
8
Do you have a weather provider set up on your system? This feels like you’re just guessing what to do without understanding what’s happening.
You must set up a weather integration first, which is what the action:
is calling. Here are your options:
Then replace weather.forecast_home
with the actual entity ID of your weather entity.
intelka
(Andree)
December 3, 2024, 1:14pm
9
Hi @Troon ,
Yes, the weather.forecast_home is pointing to the entity created by the default weather homeassistant weather provider met.no
After waiting a bit longer the changes did not make any effect, so I rebooted my homeassistant server and that did the trick.
Now I can use my mqtt.publish using the weather information as before.
Will mark the comment you made as solution.
Appreciate all the help @Troon
Best regards,
Andree
