Mqtt.py log warning "No matching payload found for entity"
Arg… I can confirm same. Must be save in database somewhere other than the .log file. Probably contributing the growing size of my .db file. Well still good enough for my goal of only seeing useful info in the log file.
That looks like an entry from the “info” or “about” screen in the GUI, isn’t it? As @AhmadK discovered the logger method does not seem to clean that up. Only cleans up the home-assistant.log file.
Mine are configured like your first exmaple:
binary_sensor:
  - platform: mqtt
    state_topic: "unosensor"
    device_class: safety
    payload_on: "1_ON"
    payload_off: "1_OFF"
  - platform: mqtt
    payload_on: "2_ON"
    payload_off: "2_OFF"
But where are you seeing the error? in the .log file or the GUI? We’re learning that they seem to be separate sets of data unfortunately.
@ee1 I’m seeing the error appear in /dev-info panel in the HA GUI. I’ve not been checking through the full log file.
Thanks for sharing how you have your binary_sensors configured.
Ok that makes sense then.
@kanga_who can you confirm that with the .py edit you don’t have the errors in either your .log file or at /dev-info? Might have to go back to that solution.
That’s correct
I am using HA 0.88.1 running on a Ubuntu Linux machine (not with docker). I followed the steps from @kanga_who . I can confirm that it works perfect!!!
@pvizeli, maybe it is time to revert your PR :slight_smile: ?
this is not working for me on 0.88.2, it was working before OK
Have you used the new folder & files inside folders naming structure for custom_components?
Yes, I have.
I get this error: seems like with the new changes (now on 0.89 also) all platforms will be loaded from the same source as the component. This means that if you want to override a built-in component/platform with a custom version, you will need to copy over all component and platform files, not just the one you want to load
where can I get all components and platform files for mqtt?
this is the error messages I get:
Unable to prepare setup for platform mqtt.binary_sensor: Could not set up all dependencies.
9:31 setup.py (ERROR) - message first occured at 9:31 and shows up 16 times
Unable to set up dependencies of mqtt.binary_sensor. Setup failed for dependencies: mqtt
9:31 helpers/config_validation.py (WARNING)
Unable to find platform mqtt. Search path was limited to path of component: custom_components
9:31 loader.py (ERROR) - message first occured at 9:31 and shows up 10 times
So, not sure if this is an option or not but I’ll throw mine in… I originally used rules in Tasmota to convert the RF code to ON/OFF and send it out MQTT to the correct topic “IE: if 12345A then publish house/433mhz/front_door ON”. This works great for just a few devices. However, I have about 4 motion sensors and 10-12 door sensors.
What I do now is the same thing but I use nodeRED. Anything coming in gets sent to the correct MQTT topic and published. I no longer have anything coming into HA via tele/RF_Bridge_Kitchen/RESULT so I no longer have that warning.
Added benefit is now I also retain the state so HA keeps door positions after a reboot and it is scaleable with just adding a node.
Just a thought. Take it for whatever you want. :slight_smile:
I do have over 20 sensors, so not really an option to me by using rules, I need access to the code of the full component for MQTT and copy it under custom components and then do the modifications there, but I do not know where to find the build in component/platform to do this.
your suggestion on NodeRed seems like an option, but if possible I would like to use HASSIO, but I will switch if this does not get fixed soon
I am using a standard Sonoff RF bridge with standard Sonoff RF sensors. I have two outdoors and 5 indoors. And I have 2 door sensors and 4 window sensors also Sonoff RF.
They all send to the same Sonoff RF Bridge running the Tasmota software which is very popular among Home Assistant owners.
And we all make binary_sensors that look for the tele/sonoffbridge/RESULT MQTT topic.
I looked at the Tasmota documentation and I cannot find a configuration where e.g. the unique ID of the sensor can be part of the MQTT topic name. That would be the working solution but then it is Tasmota that would need a feature enhancement. And it is not really needed. From an MQTT perspective there is nothing wrong in having a topic for an RF receiver and put the unique ID in the payload.
And we all follow the standard straight method to create a binary_sensor in Home Assistant.
I now - just by having me and my wife walking around the house triggering the motion sensors 1000s of log entries. Many 1000s now that I have installed the last motion sensor. This warning has no other purpose than wearing out the SD card on a Raspberry and loading Home Assistant doing useless IO. This warning has no purpose and you can see both from this forum post and from reactions on https://github.com/home-assistant/home-assistant/pull/11836 all the way from before the pull till very recently that the effect is all negative and not a single positive. Noone needs these warnings. They harm and do no good. That code change should be reverted. Or at least the log level should be lowered to debug. Normal log level should not flood the logs with useless info. Please revert this @pvizeli
would you share your code in nodered?
Sure, I posted it on another thread.
thank you!
For your info, OMG now implements the possibility to add the sensor received value at the end of the topic on which the information are published.
Enabling by the way to have one topic per sensor, this should avoid your issue of logs flooding.
I tried to import to clipboard, but does not allow me to move forward, I do not know how to use NodRed, is there something else I need to download not included on the default node red configuration?
On the off chance you’re not following the link I’ll post the full thing here.
You’ll need to change the verbage, keycodes, and topics to whatever you want but hopefully you’ll be able to figure out the flow.
[{“id”:“e6c10435.fd7f98”,“type”:“tab”,“label”:“433mhz to MQTT”,“disabled”:false,“info”:“This takes 433mhz input and outputs to the correct MQTT topic”},{“id”:“7ceb86b2.01f3f8”,“type”:“mqtt in”,“z”:“e6c10435.fd7f98”,“name”:“Sonoff RF Incoming”,“topic”:“house/rfbridge1/tele/RESULT”,“qos”:“0”,“broker”:“2b51ea82.8463b6”,“x”:100,“y”:200,“wires”:[[“428ee070.8fd66”,“84f4f92c.ade0f8”]]},{“id”:“428ee070.8fd66”,“type”:“debug”,“z”:“e6c10435.fd7f98”,“name”:“”,“active”:false,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“false”,“x”:320,“y”:130,“wires”:},{“id”:“84f4f92c.ade0f8”,“type”:“json”,“z”:“e6c10435.fd7f98”,“name”:“Convert to Object”,“property”:“payload”,“action”:“obj”,“pretty”:false,“x”:260,“y”:280,“wires”:[[“76b181d9.a1faa”,“47fd8e3d.42284”]]},{“id”:“76b181d9.a1faa”,“type”:“debug”,“z”:“e6c10435.fd7f98”,“name”:“JSON to Object”,“active”:false,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“payload”,“x”:480,“y”:240,“wires”:},{“id”:“47fd8e3d.42284”,“type”:“switch”,“z”:“e6c10435.fd7f98”,“name”:“Select Door and State”,“property”:“payload.RfReceived.Data”,“propertyType”:“msg”,“rules”:[{“t”:“eq”,“v”:“30BE0A”,“vt”:“str”},{“t”:“eq”,“v”:“30BE0E”,“vt”:“str”},{“t”:“eq”,“v”:“33530A”,“vt”:“str”},{“t”:“eq”,“v”:“33530E”,“vt”:“str”},{“t”:“eq”,“v”:“2FEF0A”,“vt”:“str”},{“t”:“eq”,“v”:“2FEF0E”,“vt”:“str”},{“t”:“eq”,“v”:“30220A”,“vt”:“str”},{“t”:“eq”,“v”:“30220E”,“vt”:“str”},{“t”:“eq”,“v”:“2D670A”,“vt”:“str”},{“t”:“eq”,“v”:“2D670E”,“vt”:“str”},{“t”:“eq”,“v”:“33380A”,“vt”:“str”},{“t”:“eq”,“v”:“33380E”,“vt”:“str”},{“t”:“eq”,“v”:“32760A”,“vt”:“str”},{“t”:“eq”,“v”:“32760E”,“vt”:“str”},{“t”:“eq”,“v”:“2F010A”,“vt”:“str”},{“t”:“eq”,“v”:“2F010E”,“vt”:“str”},{“t”:“eq”,“v”:“2ED50A”,“vt”:“str”},{“t”:“eq”,“v”:“2ED50E”,“vt”:“str”},{“t”:“eq”,“v”:“2CF00A”,“vt”:“str”},{“t”:“eq”,“v”:“2CF00E”,“vt”:“str”},{“t”:“eq”,“v”:“32580A”,“vt”:“str”},{“t”:“eq”,“v”:“32580E”,“vt”:“str”}],“checkall”:“false”,“repair”:false,“outputs”:22,“x”:490,“y”:470,“wires”:[[“31e6e3da.39580c”],[“1e7a7f66.2c37d1”],[“2d21974f.0969d8”],[“f9c8103c.ed944”],[“23d35be0.d23004”],[“c500a26e.4ca64”],[“acb1b975.58bd68”],[“dae5d5ae.1a3f78”],[“7fc87cf9.05a724”],[“af3b73b3.2f0d6”],[“76d72240.1dbd1c”],[“4ace0758.f04d08”],[“9289e22.928fc2”],[“fb20963a.819728”],[“bf193261.8abd6”],[“60af8b2.da78474”],[“89b76642.dbc618”],[“d74df00f.a5e05”],[“a32a4909.5986c8”],[“2b5887cb.89d0b8”],[“5801191a.4fa798”],[“a205853c.977708”]],“outputLabels”:[“Girls Door Opened”,“Girls Door Closed”,“M. Bath Door Opened”,“M. Bath Door Closed”,“Front Garage Opened”,“Front Garage Closed”,“Shop Door Opened”,“Shop Door Closed”,“M. Bedroom Door Opened”,“M. Bedroom Door Closed”,“Front Door Opened”,“Front Door Closed”,“Back Door Opened”,“Back Door Closed”,“Office Door Opened”,“Office Door Closed”,“Boys Door Opened”,“Boys Door Closed”,“Garage Cover Opened”,“Garage Cover Closed”,“Garage Door Opened”,“Garage Door Closed”]},{“id”:“1af48cab.b6e013”,“type”:“debug”,“z”:“e6c10435.fd7f98”,“name”:“Test Open - Attach to node to test”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“payload”,“x”:1290,“y”:80,“wires”:},{“id”:“76232b7b.e90934”,“type”:“debug”,“z”:“e6c10435.fd7f98”,“name”:“Test Closed - Attach to node to test”,“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“payload”,“x”:1290,“y”:130,“wires”:},{“id”:“1e7a7f66.2c37d1”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Girls Door - Closed”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/Girls_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“OFF”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:800,“y”:100,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“31e6e3da.39580c”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Girls Door - Opened”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/Girls_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“ON”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:810,“y”:60,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“ba9e79d4.7bd868”,“type”:“mqtt out”,“z”:“e6c10435.fd7f98”,“name”:“Send to Home Assistant”,“topic”:“”,“qos”:“”,“retain”:“”,“broker”:“2b51ea82.8463b6”,“x”:1430,“y”:530,“wires”:},{“id”:“f9c8103c.ed944”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“M. Bathroom Door - Closed”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/m_bath_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“OFF”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:1040,“y”:240,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“2d21974f.0969d8”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“M. Bathroom Door - Opened”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/m_bath_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“ON”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:1040,“y”:200,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“dae5d5ae.1a3f78”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Shop Door - Closed”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/shop_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“OFF”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:790,“y”:490,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“acb1b975.58bd68”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Shop Door - Opened”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/shop_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“ON”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:800,“y”:450,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“af3b73b3.2f0d6”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“M. Bedroom Door - Closed”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/m_bed_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“OFF”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:1040,“y”:320,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“7fc87cf9.05a724”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“M. Bedroom Door - Opened”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/m_bed_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“ON”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:1040,“y”:280,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“d74df00f.a5e05”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Boys Door - Closed”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/Boys_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“OFF”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:800,“y”:180,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“89b76642.dbc618”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Boys Door - Opened”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/Boys_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“ON”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:800,“y”:140,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“60af8b2.da78474”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Office Door - Closed”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/office_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“OFF”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:820,“y”:400,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“bf193261.8abd6”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Office Door - Opened”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/office_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“ON”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:820,“y”:360,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“fb20963a.819728”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:" Back Door - Closed",“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/back_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“OFF”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:1050,“y”:560,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“9289e22.928fc2”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Back Door - Opened”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/back_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“ON”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:1060,“y”:520,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“c500a26e.4ca64”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Front Garage Door - Closed”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/f_garage_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“OFF”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:810,“y”:800,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“23d35be0.d23004”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Front Garage Door - Opened”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/f_garage_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“ON”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:810,“y”:760,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“4ace0758.f04d08”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Front Door - Closed”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/front_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“OFF”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:1050,“y”:640,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“76d72240.1dbd1c”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Front Door - Opened”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/front_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“ON”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:1060,“y”:600,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“a205853c.977708”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Garage Door - Closed”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/garage_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“OFF”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:790,“y”:710,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“5801191a.4fa798”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Garage Door - Opened”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/garage_door”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“ON”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:790,“y”:670,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“2b5887cb.89d0b8”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Garage Cover - Closed”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/garage_cover”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“OFF”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:800,“y”:890,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“a32a4909.5986c8”,“type”:“change”,“z”:“e6c10435.fd7f98”,“name”:“Garage Cover - Opened”,“rules”:[{“t”:“delete”,“p”:“payload”,“pt”:“msg”},{“t”:“set”,“p”:“topic”,“pt”:“msg”,“to”:“house/433mhz/garage_cover”,“tot”:“str”},{“t”:“set”,“p”:“qos”,“pt”:“msg”,“to”:“1”,“tot”:“str”},{“t”:“set”,“p”:“retain”,“pt”:“msg”,“to”:“true”,“tot”:“str”},{“t”:“set”,“p”:“payload”,“pt”:“msg”,“to”:“ON”,“tot”:“str”}],“action”:“”,“property”:“”,“from”:“”,“to”:“”,“reg”:false,“x”:800,“y”:850,“wires”:[[“ba9e79d4.7bd868”]]},{“id”:“2b51ea82.8463b6”,“type”:“mqtt-broker”,“z”:“”,“name”:“Home Assistant”,“broker”:“192.168.0.1”,“port”:“1883”,“clientid”:“”,“usetls”:false,“compatmode”:true,“keepalive”:“60”,“cleansession”:true,“birthTopic”:“”,“birthQos”:“0”,“birthPayload”:“”,“closeTopic”:“”,“closeQos”:“0”,“closePayload”:“”,“willTopic”:“”,“willQos”:“0”,“willPayload”:“”}]
