Hello everybody,
how can I implement this in home assistant?
Zigbee2mqtt is already working well. The only thing I haven’t done is to integrate Domoticz via mqtt.
thanks in advance
Hello everybody,
thanks in advance
What you need to is build sensor , binarysensor , switches , lights
base on the mqtt
eg
- platform: mqtt
state_topic: "nodered/motion"
qos: 2
payload_on: "ON"
payload_off: "OFF"
device_class: motion
this binarysensor looking at “nodered/motion” turning on/off “Office Motion”
and the office light
inside my light yaml i have
- platform: mqtt
state_topic: "stat/office/POWER"
command_topic: "cmnd/office/POWER"
payload_on: "ON"
payload_off: "OFF"
qos: 0
will create a lights switch
Hi there,
this is a switch for the roller shutters. from fibaro
do I need the mqtt cover?
Yeah, that would be the easiest if you want the right icons on the front end and to be able to make generic cover.open calls to it without having to remember “oh yeah, I made that a switch and have to call switch.turn_on to open it”.
