It’s time for the August release and there is some serious good stuff this time. The core of Home Assistant has gone some serious clean up and a bump in test coverage thanks to @balloob. If you’re a developer, make sure you read up on the deprecation notices. @fabaff did another great round of documenting all the various components.
MQTT Support ![](upload://uqI82plknJanhdLEIzgovfbz9Z2.png) The big new addition in this release is the support for the MQTT protocol by @fabaff with some help from @balloob. It will now be possible to integrate any IoT device that talks via MQTT. For the initial release we support connecting Home Assistant to a broker (no TLS yet). Components can now subscribe and publish to MQTT topics (see the example) and also support for the automation component has been added. For more information, see the MQTT component page.
# Example configuration.yaml entry
mqtt:
broker: IP_ADDRESS_BROKER
# All the other options are optional:
port: 1883
keepalive: 60
qos: 0
username: your_username
password: your_secret_password
Raspberry Pi GPIO Support ![](upload://bQSyDl6X2hw5f1AS8G4rlxcBQI0.png) @gbarba has contributed support to use the general purpose input and output pins on a Raspberry Pi as switches inside Home Assistant.
switch:
platform: rpi_gpio
ports:
11: Fan Office
12: Light Desk
ASUSWRT based routers ![](upload://8mQUwaiWCH1SmSYhFy72lwwvbFp.png) @persandstrom has contributed support to do prescence detection using ASUSWRT based routers.
device_tracker:
platform: asuswrt
host: YOUR_ROUTER_IP
username: YOUR_ADMIN_USERNAME
password: YOUR_ADMIN_PASSWORD
Logitech Squeezebox media player support ![](upload://f9iIkIbs6W8Xftj8Y8NyEWLpeLy.png) @persandstrom also contributed support for the Logitech Squeezebox media player. This allows you to control your Logitech Squeezebox from Home Assistant.
media_player:
platform: squeezebox
host: 192.168.1.21
port: 9090
username: user
password: password
Slack notification support ![](upload://EFX15TEiotAa7pYgC7UTpT95Oc.png) @jamespcole has contributed a Slack platform for the notification platform. This allows you to deliver messages to any channel.
notify:
platform: slack
api_key: ABCDEFGHJKLMNOPQRSTUVXYZ
default_channel: '#general'
Edimax Smart Switches support ![](upload://znzi2ETHKOpWlDMYB158RkxANWl.png) @rkabadi has contributed support for integrating Edimax Smart Switches into Home Assistant.
switch:
platform: edimax
host: 192.168.1.32
username: YOUR_USERNAME
password: YOUR_PASSWORD
name: Edimax Smart Plug
RFXtrx sensor support @danielhiversen has contributed support for RFXtrx sensors. It supports sensors that communicate in the frequency range of 433.92 MHz.
- platform: rfxtrx
device: PATH_TO_DEVICE
The path to your device, e.g. /dev/serial/by-id/usb-RFXCOM_RFXtrx433_A1Y0NJGR-if00-port0
TEMPer temperature sensor support Support for Temper temperature sensors has been contributed by @rkabadi.
platform: temper
This is a companion discussion topic for the original entry at https://home-assistant.io/blog/2015/08/09/mqtt-raspberry-pi-squeezebox-asuswrt-support/
