Hello Together,
I am quite new to Home-Assistant and am doing my first project right now.
I use the following addon to receive data from several thermostats.
The output looks like this.
homeassistant/sensor/currentcost/Ambient_Weather_F007TH_Thermo-Hygrometer/null {“time” : “2019-02-15 18:32:08”, “model” : “Ambient Weather F007TH Thermo-Hygrometer”, “device” : 253, “channel” : 1, “battery” : “Ok”, “temperature_C” : 6.667, “humidity” : 58, “mic” : “CRC”}
homeassistant/sensor/currentcost/Ambient_Weather_F007TH_Thermo-Hygrometer/null {“time” : “2019-02-15 18:32:14”, “model” : “Ambient Weather F007TH Thermo-Hygrometer”, “device” : 135, “channel” : 2, “battery” : “Ok”, “temperature_C” : 23.444, “humidity” : 47, “mic” : “CRC”}
The output always has the same state_topic:
The thermostats differ only in “device” and “channel”.
When I try to receive data via the mqtt sensor, I always receive data from all thermostats simultaneously.
how can I distinguish the thermostats from each other and make a separate display for each one?
I use this code
- platform: mqtt
state_topic: “homeassistant/sensor/currentcost/Ambient_Weather_F007TH_Thermo-Hygrometer/null”
unit_of_measurement: “°C”
value_template: ‘{{ value_json.temperature_C }}’
And the same with a different name for the second sensor.
