MQTT Reconnectting after update
Has anyone else seen an issue with constant MQTT reconnects?
Im running Mosquito on the local machine, everything more or less default. HASS is 0.22.0, on a Xubuntu 14.14 machine.
cheers,
Is there anything else connecting with the same account and device id?
this is from the mosquitto console - i cannot see another with the same name, it is fairly unique. unless HASS is running twice? as a daemon and as a local?
1467107430: Using default config.
1467107430: Opening ipv4 listen socket on port 1883.
1467107430: Opening ipv6 listen socket on port 1883.
1467107431: New connection from 127.0.0.1 on port 1883.
1467107431: New client connected from 127.0.0.1 as dadCloud-HASS (c1, k60).
1467107432: New connection from 127.0.0.1 on port 1883.
1467107433: Socket error on client <unknown>, disconnecting.
1467107433: New connection from 127.0.0.1 on port 1883.
1467107433: Client dadCloud-HASS already connected, closing old connection.
1467107433: Client dadCloud-HASS disconnected.
1467107433: New client connected from 127.0.0.1 as dadCloud-HASS (c1, k60).
1467107434: Socket error on client <unknown>, disconnecting.
1467107434: New connection from 127.0.0.1 on port 1883.
1467107434: Client dadCloud-HASS already connected, closing old connection.
1467107434: Client dadCloud-HASS disconnected.
1467107434: New client connected from 127.0.0.1 as dadCloud-HASS (c1, k60).
1467107435: Socket error on client <unknown>, disconnecting.
1467107435: New connection from 127.0.0.1 on port 1883.
EDIT: cant see it running two instances…
I have been seeing this a lot since I reinstalled my PI3 with the AIO Installer a few weeks ago.
