Hi, since mid-February the Ring Mqtt entity tells me “This entity is no longer served by the mqtt integration.” How come? How can I solve it? I installed “Manual MQTT Alarm Control Panel” and inserted this code into configuration.yaml as suggested, but I see what is attached but when pressed the alarm does not activate or deactivate, in short it doesn’t work. Is there any step I skipped? Thank you
alarm_control_panel:
- platform: manual_mqtt
state_topic: "home/alarm"
command_topic: "home/alarm/set"
code_arm_required: false # Se vuoi richiedere un codice per armare, metti true
payload_arm_home: "ARM_HOME"
payload_arm_away: "ARM_AWAY"
payload_disarm: "DISARM"
