hi everyone, I try to integrate my new shelly gen2 device as ble monitor to check if some device in at the room.
my first try, to scan with an custom mqtt-room script and send this information to HA (works fine) but I’m not able to integrate mqtt_room in my HA configuration
my goal would be, according the specified room (topic) and respective signal strength locate my mobile device
are there anyone who have a running and successful setup
Hi, the Bermuda BLE Trilateration project could be better solution to use Shelly Plus devices as BT proxy. (GitHub - agittins/bermuda: Bermuda Bluetooth/BLE Triangulation / Trilateration for HomeAssistant) In this case, you don not need to setup any custom Shelly script because the built in HA script enough. Moreover, you do not need to use it via MQTT because the Bermuda project is an integration into HA and communicate with the Shelly devices via the native Shelly integration (which is not MQTT). I only use ESPresence project to get the IRK for Apple devices and I also use the HA’s builtin “Private BLE Device” integration to handle Apple BLE privacy… All solution is very simple. I hope it helps.
