I’m trying the MQTT Room Presence component with room assistant ( https://github.com/mKeRix/room-assistant ), for BLE detection. Unfortunately, it seems to send a lot of updates with distance changes. It sends at least one per second, sometimes more. I really only need it to send an update every 5 seconds or less.
Any way to achieve this?
“room-assistant” is a client for Home Assistant MQTT broker, so the update rate is related to room-assistant configuration, and not to HA.
To achieve a low update rate, you have to contact the room-assistant developer.
Yeah I know, thanks.
I’ve submitted a pull request for that a while after posting here
How did you solve this ?
Check the “update_frequency” option for the BLE tracker on the github page.
how does this work for you? do you mind sharing your setup?
