MQTT Script Help
Im having some trouble with my Python script authentication to my MQTT Broker.
I have a PIR Sensor connected to a Pi and a python script that will publish its state to home assistant. I have this bit working just fine if I don’t use authentication on my broker.
The bit I’m stuck with is how to incorporate my brokers authentication into my python script so I can keep it secure. Ive googled around online and so many people script it in different ways and I cant find a way that works with my script.
Here is my script below, can someone help me incorporate a line so I can add my brokers username and password.
#!/usr/bin/python
#|R|a|s|p|b|e|r|r|y|P|i|-|S|p|y|.|c|o|.|u|k|
# pir_1.py
# Detect movement using a PIR module
# Author : Matt Hawkins
# Date   : 21/01/2013
# Import required Python libraries
import RPi.GPIO as GPIO
import time
import paho.mqtt.publish as publish
# Use BCM GPIO references
# instead of physical pin numbers
GPIO.setmode(GPIO.BCM)
# Define GPIO to use on Pi
GPIO_PIR = 4
print "PIR Module Test (CTRL-C to exit)"
# Set pin as input
GPIO.setup(GPIO_PIR,GPIO.IN)      # Echo
Current_State  = 0
Previous_State = 0
try:
  print "Waiting for PIR to settle ..."
  # Loop until PIR output is 0
  while GPIO.input(GPIO_PIR)==1:
    Current_State  = 0
  print "  Ready"
  # Loop until users quits with CTRL-C
  while True :
    # Read PIR state
    Current_State = GPIO.input(GPIO_PIR)
    if Current_State==1 and Previous_State==0:
      # PIR is triggered
      print "  Motion detected!"
      publish.single("motion/motion", "Motion Detected", retain=True, hostname="172.28.8.110")
      # Record previous state
      Previous_State=1
    elif Current_State==0 and Previous_State==1:
      # PIR has returned to ready state
      print "  Ready"
      publish.single("motion/motion", "No Motion", retain=True, hostname="172.28.8.110")
      Previous_State=0
    # Wait for 10 milliseconds
    time.sleep(0.01)
except KeyboardInterrupt:
  print "  Quit"
  # Reset GPIO settings
  GPIO.cleanup()
The api doc for your library is at https://pypi.python.org/pypi/paho-mqtt#publishing
From that, I think you need your publish lines to be
      publish.single("motion/motion", "No Motion", retain=True, hostname="172.28.8.110", auth = {'username': "yourusername", 'password': "Your Password"})
Awesome worked perfectly! So simple too! I couldn’t find that anywhere.
