I have successfully used below MQTT select code in Home Assistant configuration.yaml for controlling the horizontal vane of my Mitsubishi MSZ-MH25VE heatpump with a select object in the lovelace GUI:
select:
- platform: mqtt
unique_id: hpwvc
command_topic: mitsubishi2mqtt/heatpump/wideVane/set
state_topic: mitsubishi2mqtt/heatpump/state
name: "Heatpump Horizontal Vane Control"
options:
- "SWING"
value_template: '{{ value_json.wideVane }}'
However, after Home Assistant 2022.3 version upgrade and onward, I get the following log warning messages:
- The ‘send_if_off’ option is deprecated, please remove it from your configuration
- The ‘hold_modes’ option is deprecated, please remove it from your configuration
What would the correct way be in Home Assistant 2022.3 and onward to achieve the same as above?
I can see in the Home Assistant 2022.3 release notes, there are breaking changes for MQTT, but I do not understand where the MQTT code should reside now, nor if the above code is still valid.
Any help guiding me in the right direction would be greatly appreciated.
All other control of the heatpump is done by the climate object, but it does not seem to have support for a horizontal vane.
For info: Below sensor code in configuration.yaml is reading the compressor frequency from the same heatpump, and this is still working without errors or warnings:
- platform: mqtt
unique_id: hpcmp
unit_of_measurement: "Hz"
name: "Heatpump Compressor Frequency"
value_template: '{{ value_json.compressorFrequency }}'
