Hi.
I am not able to get the Mqtt Select to work.
Get the following error when checking the config:
Setup is at the moment:
config.yaml
select: !include select.yaml
select.yaml
- platform: mqtt
state_topic: "custom/select/husmodus/01"
command_topic: "custom/select/husmodus/01/set"
options:
-"Normal"
-"Borte"
-"Ferie"
-"Natt"
Also have tried without seperate select.yaml file with current code in configuration.yaml file with same result:
#Select
select:
- platform: mqtt
options:
- "Option 1"
- "Option 2"
What am i doing wrong?
