[MQTT] Send binary payload after 2024.8 update
Hi all,
Since update 2024.8 I have the message that the payload_template parameter of MQTT publish will be deprecated in 2025.2.0.
In most cases it worked to replace payload_template by payload :+1:. However, there is one place where it changes the data and breaks the functionality, and thatā€™s when I need to send a binary value to an MQTT to RS485 gateway that will poll a solar controller.
In this case, the data is sent as a string of bytes mixed with characters and hexadecimal sequences.
Here is the script used to reproduce the problem :
data_template:
  retain: true
  topic: test/sendbin
  payload: >
    {{ pack(0x0104, ">H") }}
    {{ pack(0x3100, ">H") }}
    {{ pack(0x0014, ">H") }}
    {{ pack(0xFEF9, ">H") }}
action: mqtt.publish
And here are the results in ā€œMQTT Explorerā€.
In the first case (payload) we receive a string of bytes (bā€™\x01\x041\x00\x14\xfe\xf9ā€™), in the second case (payload_template) we receive a string of 8 characters (few of which are printable), which is what I want.
Anyone have any ideas on how I can fix this? Or do I need to open a bug report?
Maybe Iā€™ve done it all wrong and thereā€™s a better way? :upside_down_face:
Thanks.
The payload one is right though, isnā€™t it?
The payload I got with payload_template, yes, but not the big string of mixed chars and hex values.
I can live with payload_template for now, but given the deprecation Iā€™ll have to change.
I honestly donā€™t know what you mean by this but, I had (I think) a similar issue whereby I was calling a script (that had mqtt.publish in it and I used the variable {{ payload }} for `payload, so it looked like this:
- action: mqtt.publish
    topic "..."
    payload_template "{{ payload }}"
This worked with payload_template but not with payload and some kind soul (thanks, @123) suggested changing the variable to something other than payload ā€¦and it worked!
so it now looks like:
    topic "..."
    payload "{{ message }}"
Is this applicable to you?
Thanks for your hint. Unfortunately I donā€™t use a variable in the payload, so the case is not quite the same.
Iā€™ll try to be clearer.
In both cases the payload is the same:
If I use payload_template:, I get this MQTT message:
And if I use payload:, I get this:
In the first case, I have my 8 characters (4x2), but in the second I have 32 characters, which no longer corresponds to the payload at all.
what should the result look like? (is the payload_template (below) correct?
Iā€™m wondering whether you need a filter. Appreciating that you are not using a variable, one of the suggestions that @123 gave me was to use:
{{ desc[should] | to_json }}
would that correspond to:
    {{ pack(0x0104, ">H") | to_json }}
    {{ pack(0x3100, ">H") | to_json }}
    {{ pack(0x0014, ">H") | to_json }}
    {{ pack(0xFEF9, ">H") | to_json }}
Iā€™m guessing that | to_json is incorrect for your use case, but perhaps there is another filter for you? Is the payload in a particular format?
ā€¦perhaps:
    {{ pack(0x0104, ">H") | to_json(ensure_ascii=False) }}
    {{ pack(0x3100, ">H") | to_json(ensure_ascii=False) }}
    {{ pack(0x0014, ">H") | to_json(ensure_ascii=False) }}
    {{ pack(0xFEF9, ">H") | to_json(ensure_ascii=False) }}
The result should be the value 0x010431000014FEF9, which is represented in MQTT explorer by:
Unfortunately, JSON format is not an option, as the controller expects an 8-byte hex command. And I canā€™t modify it. :confused:
Thanks for the advice, Iā€™ve tried it, including other solutions, but nothing conclusive so far.
Iā€™ve opened a bug report:
Weā€™ll see what happens. :thinking:
Someone way more capable than me may be able to chime in. Either way, best of luck!
Well it looks like it was an issue, jbouwh made a PR to fix it. :grinning:
Iā€™ll wait until I can test it and then Iā€™ll close this topic.
Tested just now with version 2024.9.0, everything works fine :1st_place_medal:
