Hello everyone.
I’v been using HA for 2-3 years but I still have a lot of problem in understanding the logic under the hood of a lot of things.
A little background before my question:
I’ve created few sensors (with ESP8266 and DHT22) and have them send to HA via MQTT readings (temp, hum and battery voltage) every 5 minutes.
Sensor are automatically discovered by HA because every sensor publish a set of configuration JASON values under homeassistant/sensor
example:
homeassistant/sensor/Studio/voltage:
"device_class": "voltage",
"name": "Voltaggio Batteria Studio",
"state_topic": "sensor/Studio/state",
"unit_of_measurement": "V",
"value_template": "{{ value_json.voltage }}"
and in sensor/Studio/state I’ve got the following reading:
"temperature": "21.80",
"humidity": "50.40",
"humidity": "50.30",
"voltage": "3.31"
It’s all working smootly so far.
My Problem:
I want to add somewhere a state/entity/something for each sensor in which I store the timestamp every time I change the battery of a sensor (each battery last more or less 30-40 days)
I’ve already created an automation that is triggered when battery voltage of a sensor change from a low to a high value.
Where can I store such information and how ?
Is it better to create an helper or a sensor template ? or should modify the actual sensor to add an attribute to the existing entity ?
