I am trying to make a MQTT sensor with information from json.
I have this MQTT sensor:
mqtt:
- name: "Scrypted Kitchen sensor"
state_topic: "scrypted/kitchen-camera/motionDetected"
json_attributes_topic: "scrypted/kitchen-camera/ObjectDetector"
payload_on: "true"
payload_off: "false"
device_class: motion
In MQTT Exlorer, I see this:
motionDetected = true
ObjectDetector = {“detections”:[{“boundingBox”:[1048,728,498,350],“className”:“person”,“score”:0.7890625,“id”:“969995f9-d691-43bf-bf26-776b604c4cc6”,“history”:{“firstSeen”:1672323543627,“lastSeen”:1672323544236},“bestScore”:0.9921875}],“inputDimensions”:[1920,1080],“running”:true,“timestamp”:1672323544234}
How do I make a sensor with state from “className”? It works for me to make a sensor with state from ‘motionDetected’ and with ‘ObjectDetector’ as attribute:
krskrab
December 29, 2022, 5:49pm
2
json_attributes:
- className
petro
(Petro)
December 29, 2022, 6:11pm
4
it’s not in the mqtt sensor section. i.e. bad spacing
Updated first post to show, that the code is in the mqtt sensor section.
And can via Google see, that json_attributes have been removed.
petro
(Petro)
December 29, 2022, 6:37pm
6
but that error is telling you’re going straight from mqtt to json_attributes.
e.g.
mqtt:
json_attributes:
instead of
mqtt:
json_attributes:
As to the documentation
json_attributes is not a variable.
petro
(Petro)
December 29, 2022, 7:06pm
8
Then you’d just need the json_attributes_template: "{{ value }}"
I will try to explain a bit more …
It is possible for me to make a “Timestamp” sensor with the number as value. But what I want is to take a value from within “Detections” (see screenshot).
mqtt:
- name: "Scrypted Living Room sensor timestamp"
state_topic: "scrypted/living_room-camera/ObjectDetector"
value_template: "{{ value_json.timestamp }}"
How do I make the value from Detections, className as a sensor?
petro
(Petro)
December 29, 2022, 7:30pm
10
value_template: "{{ (value_json.timestamp / 1000) | timestamp_local | as_datetime }}"
Thanks, made my timestamp look better.
But I want a subset of “Detections”, the value of className.
{"detections":[{"boundingBox":[987,702,544,376],"className":"person","score":0.93359375,"id":"627487bb-0170-4456-bcc7-afb139976ad5","history":{"firstSeen":1672343055486,"lastSeen":1672343055906},"bestScore":0.98046875}],"inputDimensions":[1920,1080],"running":true,"timestamp":1672343055905}
petro
(Petro)
December 29, 2022, 7:45pm
12
value_json.detections[0].className
dvbit
(Dvbit)
May 8, 2023, 8:49pm
14
@onkelfarmor could you share your complete sensor definition?
I am struggling with the exact same problem: getting Scrypted cameras values in a HA sensor.
For simplicity I am limiting the objects detected to the first of the array and setting up separate sensors per object types (person, cat ,dog)
TX in advance
So frustrated that I think next step will be writing a short appdaemon that will solve that simple and easy.
Here you are:
mqtt:
unique_id: livingroomcametimestamp
device_class: timestamp
device:
name: Scrypted Living Room
identifiers:
- '1002'
- name: "Scrypted Living Room ClassName sensor"
value_template: "{{ value_json.detections[0].className }}"
unique_id: livingroomcamclassname
device:
identifiers:
- '1002'
- name: "Scrypted Living Room score"
value_template: "{{ value_json.detections[0].score }}"
unique_id: livingroomcamscore
device_class: power_factor
device:
identifiers:
- '1002'
- name: "Scrypted Living Room id"
value_template: "{{ value_json.detections[0].id }}"
unique_id: livingroomcamid
device:
identifiers:
- '1002'
- name: "Scrypted Living Room bestscore"
value_template: "{{ value_json.detections[0].bestScore }}"
unique_id: livingroomcambestscore
device:
identifiers:
- '1002'
