Mqtt sensor data always has unknown state
Hallo,
I am just beginning with HA and need anyhow help:
I have a wallbox, in my car a wican adapter, both are publishing mqtt data to my mqtt-broker, working as add-on in HA.
Depending on 4 events (car is incoming, car is going out, wallbox starts or stops charging the car battery) I publish 4 values in a new mqtt topic “Zoe/Energiedaten” (1). I can see the values in the mqtt-explorer (2). This works fine.
In HA file editor I add in section mqtt –sensors the sensors for the 4 mqtt data parts
   - name: "ZE - WB-Energyges"
     state_topic: "Zoe/Energiedaten"
     value_template: "{{ value_json.WallboxEnergie }}"
     unit_of_measurement: "kWh"
   - name: "ZE - ZoeBatEnergy"
     value_template: "{{ value_json.ZoeBatEnergie }}"
     unit_of_measurement: "Wh"
   - name: "ZE - ZoeSoC"
     value_template: "{{ value_json.ZoeSoC }}"
     unit_of_measurement: "%"
   - name: "ZE - Zoe_km-Stand"
     value_template: "{{ value_json.Zoe_km-Stand }}"
     unit_of_measurement: "km"
in the same manner like before for the mqtt-data from wallbox and car adapter (3).
But I don’t see the values here like the values from wallbox and car adapter.
Can somebody tell me what I did wrong?
Is home assistant connected to the mqtt broker?
What does the mqtt broker log say?
What does the home assistant system log say?
Yes, it is, all the mqtt data from the wallbox and the car adapter are valid as HA sensors.
Mosquito broker log has only entries concerning updates (alternating between off and not avalable). (HA → logbook → mosquito broker)
at service mosquitto I find this log:
2024-12-20 14:09:29: Client <unknown> closed its connection.
2024-12-20 14:11:29: New connection from 172.30.32.2:49704 on port 1883.
2024-12-20 14:11:29: Client <unknown> closed its connection.
time="2024-12-20T14:12:04+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": EOF"
2024-12-20 14:13:29: New connection from 172.30.32.2:47504 on port 1883.
2024-12-20 14:13:30: Client <unknown> closed its connection.
2024-12-20 14:14:18: Client ESP32_b3DBC0 has exceeded timeout, disconnecting.
2024-12-20 14:15:31: New connection from 172.30.32.2:33978 on port 1883.
2024-12-20 14:15:34: Client <unknown> closed its connection.
time="2024-12-20T14:16:57+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": EOF"
2024-12-20 14:17:37: New connection from 172.30.32.2:34122 on port 1883.
2024-12-20 14:17:37: Client <unknown> closed its connection.
2024-12-20 14:19:39: New connection from 172.30.32.2:34370 on port 1883.
2024-12-20 14:19:39: Client <unknown> closed its connection.
2024-12-20 14:21:39: New connection from 172.30.32.2:37524 on port 1883.
2024-12-20 14:21:39: Client <unknown> closed its connection.
time="2024-12-20T14:21:50+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": EOF"
time="2024-12-20T14:21:56+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": EOF"
2024-12-20 14:23:40: New connection from 172.30.32.2:47448 on port 1883.
2024-12-20 14:23:40: Client <unknown> closed its connection.
2024-12-20 14:25:00: Client 2iP0rmgdIy7ehusdx36unu closed its connection.
2024-12-20 14:25:28: New connection from 192.168.178.2:51847 on port 1883.
2024-12-20 14:25:42: New connection from 172.30.32.2:33348 on port 1883.
2024-12-20 14:25:42: Client <unknown> closed its connection.
time="2024-12-20T14:26:03+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/authentication\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
time="2024-12-20T14:26:03+01:00" level=error msg="Post \"http://127.0.0.1:80/authentication\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
2024-12-20 14:25:56: Bad socket read/write on client 2iP0rmgdIy7ehusdx36unu: Unknown error.
2024-12-20 14:26:05: New connection from 192.168.178.2:47551 on port 1883.
2024-12-20 14:26:05: New client connected from 192.168.178.2:47551 as 2iP0rmgdIy7ehusdx36unu (p2, c1, k60, u'mqtt-benutzer').
2024-12-20 14:26:12: Saving in-memory database to /data//mosquitto.db.
2024-12-20 14:27:44: New connection from 172.30.32.2:46404 on port 1883.
2024-12-20 14:27:44: Client <unknown> closed its connection.
time="2024-12-20T14:27:54+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": EOF"
2024-12-20 14:29:43: New connection from 172.30.32.2:33886 on port 1883.
2024-12-20 14:29:43: Client <unknown> closed its connection.
2024-12-20 14:31:43: New connection from 172.30.32.2:39296 on port 1883.
2024-12-20 14:31:43: Client <unknown> closed its connection.
2024-12-20 14:33:44: New connection from 172.30.32.2:46546 on port 1883.
2024-12-20 14:33:44: Client <unknown> closed its connection.
2024-12-20 14:35:44: New connection from 172.30.32.2:33446 on port 1883.
2024-12-20 14:35:44: Client <unknown> closed its connection.
2024-12-20 14:37:44: New connection from 172.30.32.2:41854 on port 1883.
2024-12-20 14:37:45: Client <unknown> closed its connection.
2024-12-20 14:39:45: New connection from 172.30.32.2:54800 on port 1883.
2024-12-20 14:39:45: Client <unknown> closed its connection.
2024-12-20 14:41:45: New connection from 172.30.32.2:49954 on port 1883.
2024-12-20 14:41:45: Client <unknown> closed its connection.
2024-12-20 14:43:46: New connection from 172.30.32.2:33654 on port 1883.
2024-12-20 14:43:47: Client <unknown> closed its connection.
2024-12-20 14:45:47: New connection from 172.30.32.2:47034 on port 1883.
2024-12-20 14:45:47: Client <unknown> closed its connection.
2024-12-20 14:47:47: New connection from 172.30.32.2:41822 on port 1883.
2024-12-20 14:47:47: Client <unknown> closed its connection.
2024-12-20 14:49:47: New connection from 172.30.32.2:43060 on port 1883.
2024-12-20 14:49:48: Client <unknown> closed its connection.
2024-12-20 14:51:48: New connection from 172.30.32.2:56316 on port 1883.
2024-12-20 14:51:48: Client <unknown> closed its connection.
2024-12-20 14:53:48: New connection from 172.30.32.2:51064 on port 1883.
2024-12-20 14:53:48: Client <unknown> closed its connection.
2024-12-20 14:55:48: New connection from 172.30.32.2:37802 on port 1883.
2024-12-20 14:55:48: Client <unknown> closed its connection.
2024-12-20 14:56:13: Saving in-memory database to /data//mosquitto.db.
2024-12-20 14:57:48: New connection from 172.30.32.2:48948 on port 1883.
2024-12-20 14:57:48: Client <unknown> closed its connection.
2024-12-20 14:59:48: New connection from 172.30.32.2:45844 on port 1883.
2024-12-20 14:59:48: Client <unknown> closed its connection.
time="2024-12-20T15:01:16+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": read tcp 127.0.0.1:53686->127.0.0.1:80: read: connection reset by peer"
2024-12-20 15:01:48: New connection from 172.30.32.2:53178 on port 1883.
2024-12-20 15:01:48: Client <unknown> closed its connection.
2024-12-20 15:03:51: New connection from 172.30.32.2:55992 on port 1883.
2024-12-20 15:03:51: Client <unknown> closed its connection.
2024-12-20 15:05:50: New connection from 172.30.32.2:33622 on port 1883.
2024-12-20 15:05:50: Client <unknown> closed its connection.
2024-12-20 15:07:50: New connection from 172.30.32.2:37016 on port 1883.
2024-12-20 15:07:50: Client <unknown> closed its connection.
2024-12-20 15:09:50: New connection from 172.30.32.2:55302 on port 1883.
2024-12-20 15:09:50: Client <unknown> closed its connection.
2024-12-20 15:11:50: New connection from 172.30.32.2:56274 on port 1883.
2024-12-20 15:11:50: Client <unknown> closed its connection.
time="2024-12-20T15:11:55+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": EOF"
2024-12-20 15:13:50: New connection from 172.30.32.2:57012 on port 1883.
2024-12-20 15:13:50: Client <unknown> closed its connection.
2024-12-20 15:15:51: New connection from 172.30.32.2:45992 on port 1883.
2024-12-20 15:15:51: Client <unknown> closed its connection.
2024-12-20 15:17:52: New connection from 172.30.32.2:60164 on port 1883.
2024-12-20 15:17:52: Client <unknown> closed its connection.
2024-12-20 15:19:52: New connection from 172.30.32.2:42546 on port 1883.
2024-12-20 15:19:52: Client <unknown> closed its connection.
2024-12-20 15:21:52: New connection from 172.30.32.2:46970 on port 1883.
2024-12-20 15:21:52: Client <unknown> closed its connection.
2024-12-20 15:23:52: New connection from 172.30.32.2:52266 on port 1883.
2024-12-20 15:23:52: Client <unknown> closed its connection.
2024-12-20 15:25:52: New connection from 172.30.32.2:40960 on port 1883.
2024-12-20 15:25:52: Client <unknown> closed its connection.
2024-12-20 15:26:14: Saving in-memory database to /data//mosquitto.db.
2024-12-20 15:27:52: New connection from 172.30.32.2:60850 on port 1883.
2024-12-20 15:27:52: Client <unknown> closed its connection.
2024-12-20 15:29:53: New connection from 172.30.32.2:48710 on port 1883.
2024-12-20 15:29:53: Client <unknown> closed its connection.
2024-12-20 15:31:53: New connection from 172.30.32.2:37824 on port 1883.
2024-12-20 15:31:53: Client <unknown> closed its connection.
2024-12-20 15:33:54: New connection from 172.30.32.2:59258 on port 1883.
2024-12-20 15:33:54: Client <unknown> closed its connection.
2024-12-20 15:35:54: New connection from 172.30.32.2:44960 on port 1883.
2024-12-20 15:35:54: Client <unknown> closed its connection.
2024-12-20 15:37:54: New connection from 172.30.32.2:60920 on port 1883.
2024-12-20 15:37:54: Client <unknown> closed its connection.
2024-12-20 15:39:54: New connection from 172.30.32.2:42360 on port 1883.
2024-12-20 15:39:54: Client <unknown> closed its connection.
2024-12-20 15:41:54: New connection from 172.30.32.2:43586 on port 1883.
2024-12-20 15:41:54: Client <unknown> closed its connection.
2024-12-20 15:43:19: New connection from 192.168.178.41:53187 on port 1883.
2024-12-20 15:43:19: New client connected from 192.168.178.41:53187 as ESP32_b3DBC0 (p2, c1, k30, u'mqtt-benutzer').
2024-12-20 15:43:54: New connection from 172.30.32.2:36366 on port 1883.
2024-12-20 15:43:55: Client <unknown> closed its connection.
2024-12-20 15:45:55: New connection from 172.30.32.2:35820 on port 1883.
2024-12-20 15:45:55: Client <unknown> closed its connection.
2024-12-20 15:47:55: New connection from 172.30.32.2:49798 on port 1883.
2024-12-20 15:47:55: Client <unknown> closed its connection.
2024-12-20 15:48:29: New connection from 192.168.178.41:53189 on port 1883.
2024-12-20 15:48:29: Client ESP32_b3DBC0 already connected, closing old connection.
2024-12-20 15:48:29: New client connected from 192.168.178.41:53189 as ESP32_b3DBC0 (p2, c1, k30, u'mqtt-benutzer').
2024-12-20 15:49:35: Client ESP32_b3DBC0 has exceeded timeout, disconnecting.
time="2024-12-20T15:49:41+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": EOF"
2024-12-20 15:49:55: New connection from 172.30.32.2:58856 on port 1883.
2024-12-20 15:49:55: Client <unknown> closed its connection.
2024-12-20 15:50:30: New connection from 192.168.178.41:53193 on port 1883.
2024-12-20 15:50:30: New client connected from 192.168.178.41:53193 as ESP32_b3DBC0 (p2, c1, k30, u'mqtt-benutzer').
2024-12-20 15:51:55: New connection from 172.30.32.2:49170 on port 1883.
2024-12-20 15:51:55: Client <unknown> closed its connection.
2024-12-20 15:53:55: New connection from 172.30.32.2:59550 on port 1883.
2024-12-20 15:53:55: Client <unknown> closed its connection.
2024-12-20 15:55:56: New connection from 172.30.32.2:47962 on port 1883.
2024-12-20 15:55:56: Client <unknown> closed its connection.
2024-12-20 15:56:15: Saving in-memory database to /data//mosquitto.db.
2024-12-20 15:57:56: New connection from 172.30.32.2:55742 on port 1883.
2024-12-20 15:57:56: Client <unknown> closed its connection.
2024-12-20 15:59:56: New connection from 172.30.32.2:59696 on port 1883.
2024-12-20 15:59:56: Client <unknown> closed its connection.
2024-12-20 16:01:56: New connection from 172.30.32.2:55452 on port 1883.
2024-12-20 16:01:56: Client <unknown> closed its connection.
time="2024-12-20T16:02:35+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": EOF"
2024-12-20 16:03:56: New connection from 172.30.32.2:46174 on port 1883.
2024-12-20 16:03:56: Client <unknown> closed its connection.
2024-12-20 16:05:56: New connection from 172.30.32.2:58746 on port 1883.
2024-12-20 16:05:56: Client <unknown> closed its connection.
2024-12-20 16:07:56: New connection from 172.30.32.2:42460 on port 1883.
2024-12-20 16:07:57: Client <unknown> closed its connection.
2024-12-20 16:09:57: New connection from 172.30.32.2:47526 on port 1883.
2024-12-20 16:09:57: Client <unknown> closed its connection.
2024-12-20 16:11:57: New connection from 172.30.32.2:57490 on port 1883.
2024-12-20 16:11:57: Client <unknown> closed its connection.
2024-12-20 16:13:57: New connection from 172.30.32.2:42234 on port 1883.
2024-12-20 16:13:57: Client <unknown> closed its connection.
2024-12-20 16:15:57: New connection from 172.30.32.2:51738 on port 1883.
2024-12-20 16:15:57: Client <unknown> closed its connection.
2024-12-20 16:17:57: New connection from 172.30.32.2:50596 on port 1883.
2024-12-20 16:17:57: Client <unknown> closed its connection.
2024-12-20 16:19:57: New connection from 172.30.32.2:48176 on port 1883.
2024-12-20 16:19:57: Client <unknown> closed its connection.
2024-12-20 16:21:57: New connection from 172.30.32.2:34046 on port 1883.
2024-12-20 16:21:57: Client <unknown> closed its connection.
2024-12-20 16:23:57: New connection from 172.30.32.2:55472 on port 1883.
2024-12-20 16:23:57: Client <unknown> closed its connection.
2024-12-20 16:25:57: New connection from 172.30.32.2:51776 on port 1883.
2024-12-20 16:25:57: Client <unknown> closed its connection.
2024-12-20 16:26:16: Saving in-memory database to /data//mosquitto.db.
2024-12-20 16:27:57: New connection from 172.30.32.2:49342 on port 1883.
2024-12-20 16:27:57: Client <unknown> closed its connection.
2024-12-20 16:29:57: New connection from 172.30.32.2:58894 on port 1883.
2024-12-20 16:29:57: Client <unknown> closed its connection.
2024-12-20 16:31:57: New connection from 172.30.32.2:42436 on port 1883.
2024-12-20 16:31:57: Client <unknown> closed its connection.
2024-12-20 16:33:57: New connection from 172.30.32.2:38272 on port 1883.
2024-12-20 16:33:57: Client <unknown> closed its connection.
2024-12-20 16:35:57: New connection from 172.30.32.2:41220 on port 1883.
2024-12-20 16:35:57: Client <unknown> closed its connection.
2024-12-20 16:37:57: New connection from 172.30.32.2:59422 on port 1883.
2024-12-20 16:37:57: Client <unknown> closed its connection.
2024-12-20 16:39:57: New connection from 172.30.32.2:41202 on port 1883.
2024-12-20 16:39:57: Client <unknown> closed its connection.
2024-12-20 16:41:58: New connection from 172.30.32.2:34954 on port 1883.
2024-12-20 16:41:58: Client <unknown> closed its connection.
time="2024-12-20T16:43:26+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": EOF"
2024-12-20 16:44:01: New connection from 172.30.32.2:53402 on port 1883.
2024-12-20 16:44:02: Client <unknown> closed its connection.
time="2024-12-20T16:45:52+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
time="2024-12-20T16:46:03+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/acl\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
time="2024-12-20T16:46:05+01:00" level=error msg="Post \"http://127.0.0.1:80/superuser\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
2024-12-20 16:46:12: New connection from 192.168.178.41:53194 on port 1883.
2024-12-20 16:46:12: Client 2iP0rmgdIy7ehusdx36unu has exceeded timeout, disconnecting.
time="2024-12-20T16:46:18+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/authentication\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
time="2024-12-20T16:46:19+01:00" level=error msg="Post \"http://127.0.0.1:80/authentication\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
2024-12-20 16:46:12: Bad socket read/write on client ESP32_b3DBC0: Unknown error.
2024-12-20 16:46:19: New connection from 172.30.32.2:55558 on port 1883.
2024-12-20 16:46:19: New connection from 192.168.178.41:53195 on port 1883.
2024-12-20 16:46:20: Client <unknown> closed its connection.
time="2024-12-20T16:46:27+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/authentication\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
time="2024-12-20T16:46:27+01:00" level=error msg="Post \"http://127.0.0.1:80/authentication\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
2024-12-20 16:46:20: Bad socket read/write on client ESP32_b3DBC0: Unknown error.
2024-12-20 16:46:29: Client ESP32_b3DBC0 closed its connection.
2024-12-20 16:46:32: New connection from 192.168.178.41:53196 on port 1883.
s6-rc: info: service legacy-services: stopping
time="2024-12-20T16:46:39+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/authentication\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
time="2024-12-20T16:46:39+01:00" level=error msg="Post \"http://127.0.0.1:80/authentication\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
2024-12-20 16:46:32: Bad socket read/write on client ESP32_b3DBC0: Unknown error.
time="2024-12-20T16:46:41+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/superuser\": read tcp 127.0.0.1:34562->127.0.0.1:80: read: connection reset by peer"
time="2024-12-20T16:46:42+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/acl\": read tcp 127.0.0.1:34578->127.0.0.1:80: read: connection reset by peer"
time="2024-12-20T16:46:42+01:00" level=error msg="Post \"http://127.0.0.1:80/superuser\": read tcp 127.0.0.1:34562->127.0.0.1:80: read: connection reset by peer"
2024-12-20 16:46:39: Bad socket read/write on client efe142cea2c13e87cde0: Unknown error.
2024-12-20 16:46:39: mosquitto version 2.0.18 terminating
2024-12-20 16:46:39: Saving in-memory database to /data//mosquitto.db.
s6-svwait: fatal: timed out
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[16:48:14] INFO: e[32mSSL is not enablede[0m
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
s6-rc: info: service legacy-services successfully started
[16:48:40] INFO: e[32mStarting NGINX for authentication handling...e[0m
[16:48:44] INFO: e[32mStarting mosquitto MQTT broker...e[0m
2024-12-20 16:48:45: Warning: Mosquitto should not be run as root/administrator.
2024-12-20 16:48:45: mosquitto version 2.0.18 starting
2024-12-20 16:48:45: Config loaded from /etc/mosquitto/mosquitto.conf.
2024-12-20 16:48:45: Loading plugin: /usr/share/mosquitto/go-auth.so
2024-12-20 16:48:45:  ├── Username/password checking enabled.
2024-12-20 16:48:45:  ├── TLS-PSK checking enabled.
2024-12-20 16:48:45:  └── Extended authentication not enabled.
2024-12-20 16:48:45: Opening ipv4 listen socket on port 1883.
2024-12-20 16:48:45: Opening ipv6 listen socket on port 1883.
2024-12-20 16:48:45: Opening websockets listen socket on port 1884.
2024-12-20 16:48:45: mosquitto version 2.0.18 running
2024-12-20 16:48:56: New connection from 192.168.178.32:55663 on port 1883.
2024-12-20 16:48:56: New connection from ::1:48340 on port 1883.
time="2024-12-20T16:49:03+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/authentication\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
time="2024-12-20T16:49:03+01:00" level=error msg="Post \"http://127.0.0.1:80/authentication\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
2024-12-20 16:48:56: Bad socket read/write on client mqtt-explorer-58850632: Unknown error.
2024-12-20 16:48:56: Client <unknown> disconnected due to protocol error.
2024-12-20 16:49:04: New connection from 192.168.178.41:53213 on port 1883.
2024-12-20 16:49:04: New connection from 192.168.178.2:34797 on port 1883.
2024-12-20 16:49:04: New connection from 192.168.178.50:63468 on port 1883.
time="2024-12-20T16:49:11+01:00" level=error msg="POST error: Post \"http://127.0.0.1:80/authentication\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
time="2024-12-20T16:49:11+01:00" level=error msg="Post \"http://127.0.0.1:80/authentication\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"
2024-12-20 16:49:04: Bad socket read/write on client ESP32_b3DBC0: Unknown error.
or is there anywhere an additional log?
And I do not know where to look for the home assistant system log.
additionally I found in system/log(germ.Protokolle)
  • home assistant core:
    nothing that can be relevant
    -supervisor:
e[32m2024-12-20 13:48:18.726 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 13:48:19.162 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt-benutzer'e[0m
e[31m2024-12-20 13:48:37.374 ERROR (MainThread) [supervisor.services.modules.mqtt] There is already a MQTT service in use from core_mosquittoe[0m
e[33m2024-12-20 13:49:11.940 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missing application response from core_mosquittoe[0m
e[32m2024-12-20 13:49:31.275 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/grafana/aarch64 with version 10.2.2e[0m
e[32m2024-12-20 13:50:19.632 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[33m2024-12-20 13:51:31.443 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Grafana to start, took more than 120 secondse[0m
e[33m2024-12-20 13:53:38.712 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with core_mosquitto application!e[0m
e[33m2024-12-20 13:53:46.364 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Grafana is unhealthy, restarting...e[0m
e[32m2024-12-20 13:53:53.437 INFO (SyncWorker_5) [supervisor.docker.manager] Stopping addon_core_mosquitto applicatione[0m
e[32m2024-12-20 13:53:54.995 INFO (SyncWorker_7) [supervisor.docker.manager] Stopping addon_a0d7b954_grafana applicatione[0m
e[32m2024-12-20 13:53:56.159 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 13:54:11.122 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 13:54:13.081 INFO (MainThread) [supervisor.auth] Home Assistant not running, checking cachee[0m
e[32m2024-12-20 13:54:42.955 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt-benutzer'e[0m
e[32m2024-12-20 13:54:53.905 INFO (SyncWorker_7) [supervisor.docker.manager] Cleaning addon_a0d7b954_grafana applicatione[0m
e[32m2024-12-20 13:54:55.231 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_core_mosquitto applicatione[0m
e[32m2024-12-20 13:55:20.380 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-mosquitto with version 6.4.1e[0m
e[32m2024-12-20 13:55:20.678 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/grafana/aarch64 with version 10.2.2e[0m
e[32m2024-12-20 13:56:14.318 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 13:56:20.815 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt-benutzer'e[0m
e[32m2024-12-20 13:56:20.819 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 13:56:22.685 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt-benutzer'e[0m
e[33m2024-12-20 13:57:23.379 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Grafana to start, took more than 120 secondse[0m
e[31m2024-12-20 13:57:33.197 ERROR (MainThread) [supervisor.services.modules.mqtt] There is already a MQTT service in use from core_mosquittoe[0m
e[33m2024-12-20 13:57:49.149 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Grafana is unhealthy, restarting...e[0m
e[33m2024-12-20 13:57:49.153 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon MQTT Explorer is failed, restarting...e[0m
e[32m2024-12-20 13:57:49.219 INFO (SyncWorker_2) [supervisor.docker.manager] Cleaning addon_9cf1ea8f_mqtt_explorer applicatione[0m
e[32m2024-12-20 13:57:49.223 INFO (SyncWorker_4) [supervisor.docker.manager] Stopping addon_a0d7b954_grafana applicatione[0m
e[32m2024-12-20 13:58:05.852 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_a0d7b954_grafana applicatione[0m
e[32m2024-12-20 13:58:08.732 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on smeagolworms4/mqtt-explorer with version browser-1.0.3e[0m
e[32m2024-12-20 13:59:00.528 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/grafana/aarch64 with version 10.2.2e[0m
e[33m2024-12-20 14:01:01.056 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Grafana to start, took more than 120 secondse[0m
e[33m2024-12-20 14:02:06.728 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Grafana is unhealthy, restarting...e[0m
e[32m2024-12-20 14:02:16.308 INFO (SyncWorker_1) [supervisor.docker.manager] Stopping addon_a0d7b954_grafana applicatione[0m
e[32m2024-12-20 14:02:50.925 INFO (SyncWorker_1) [supervisor.docker.manager] Cleaning addon_a0d7b954_grafana applicatione[0m
e[32m2024-12-20 14:03:28.805 INFO (MainThread) [supervisor.host.info] Updating local host informatione[0m
e[32m2024-12-20 14:03:36.936 INFO (MainThread) [supervisor.host.services] Updating service informatione[0m
e[32m2024-12-20 14:03:36.384 INFO (MainThread) [supervisor.host.network] Updating local network informatione[0m
e[32m2024-12-20 14:03:40.229 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio informatione[0m
e[32m2024-12-20 14:03:45.207 INFO (MainThread) [supervisor.host.manager] Host information reload completede[0m
e[32m2024-12-20 14:03:45.882 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/grafana/aarch64 with version 10.2.2e[0m
e[33m2024-12-20 14:05:46.049 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Grafana to start, took more than 120 secondse[0m
e[33m2024-12-20 14:06:49.159 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Grafana is unhealthy, restarting...e[0m
e[32m2024-12-20 14:06:49.565 INFO (SyncWorker_5) [supervisor.docker.manager] Stopping addon_a0d7b954_grafana applicatione[0m
e[32m2024-12-20 14:07:24.198 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_a0d7b954_grafana applicatione[0m
e[32m2024-12-20 14:08:04.577 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/grafana/aarch64 with version 10.2.2e[0m
e[33m2024-12-20 14:10:06.778 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Grafana to start, took more than 120 secondse[0m
e[33m2024-12-20 14:10:44.382 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Grafana is unhealthy, restarting...e[0m
e[32m2024-12-20 14:10:45.350 INFO (SyncWorker_7) [supervisor.docker.manager] Stopping addon_a0d7b954_grafana applicatione[0m
e[32m2024-12-20 14:11:16.365 INFO (SyncWorker_7) [supervisor.docker.manager] Cleaning addon_a0d7b954_grafana applicatione[0m
e[32m2024-12-20 14:12:25.930 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/hassio-addons/grafana/aarch64 with version 10.2.2e[0m
e[33m2024-12-20 14:14:27.978 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Grafana to start, took more than 120 secondse[0m
e[33m2024-12-20 14:15:34.480 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missing application response from core_mosquittoe[0m
e[32m2024-12-20 14:18:00.220 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.jsone[0m
e[32m2024-12-20 14:19:40.702 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state runninge[0m
e[32m2024-12-20 14:19:40.947 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisore[0m
e[32m2024-12-20 14:19:51.556 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/systeme[0m
e[32m2024-12-20 14:19:51.629 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/systeme[0m
e[32m2024-12-20 14:19:51.631 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addone[0m
e[32m2024-12-20 14:19:52.010 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/coree[0m
e[32m2024-12-20 14:19:52.030 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_servere[0m
e[32m2024-12-20 14:19:52.032 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_servere[0m
e[32m2024-12-20 14:19:52.034 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/systeme[0m
e[32m2024-12-20 14:19:52.036 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/systeme[0m
e[32m2024-12-20 14:19:52.038 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/systeme[0m
e[32m2024-12-20 14:19:52.043 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2024-12-20 14:19:52.044 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2024-12-20 14:20:27.710 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-12-20 14:20:27.832 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state runninge[0m
e[32m2024-12-20 14:20:27.834 INFO (MainThread) [supervisor.resolution.fixup] System autofix completee[0m
e[32m2024-12-20 14:20:29.602 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2024-12-20 14:24:54.910 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hacs/addons repositorye[0m
e[32m2024-12-20 14:24:55.387 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/music-assistant/home-assistant-addon repositorye[0m
e[32m2024-12-20 14:24:55.713 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/GollumDom/addon-repository repositorye[0m
e[32m2024-12-20 14:24:55.936 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repositorye[0m
e[32m2024-12-20 14:24:56.068 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repositorye[0m
e[32m2024-12-20 14:24:56.259 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repositorye[0m
e[32m2024-12-20 14:26:00.549 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 14:26:05.458 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt-benutzer'e[0m
e[32m2024-12-20 14:26:05.757 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 14:26:07.375 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt-benutzer'e[0m
e[31m2024-12-20 14:28:26.372 ERROR (SyncWorker_4) [asyncio] Future exception was never retrieved
future: <Future finished exception=HomeAssistantWSConnectionError('Connection was closed')>
supervisor.exceptions.HomeAssistantWSConnectionError: Connection was closede[0m
e[31m2024-12-20 14:28:26.575 ERROR (SyncWorker_4) [asyncio] Future exception was never retrieved
e[32m2024-12-20 14:28:28.921 INFO (MainThread) [supervisor.store] Loading add-ons from store: 84 all - 0 new - 0 removee[0m
e[32m2024-12-20 14:28:29.924 INFO (MainThread) [supervisor.store] Loading add-ons from store: 84 all - 0 new - 0 removee[0m
e[32m2024-12-20 14:51:01.664 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2024-12-20 15:20:29.639 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state runninge[0m
e[32m2024-12-20 15:20:29.646 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisore[0m
e[32m2024-12-20 15:20:30.428 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/systeme[0m
e[32m2024-12-20 15:20:30.436 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/systeme[0m
e[32m2024-12-20 15:20:30.438 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addone[0m
e[32m2024-12-20 15:20:31.346 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/coree[0m
e[32m2024-12-20 15:20:31.349 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_servere[0m
e[32m2024-12-20 15:20:31.351 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_servere[0m
e[32m2024-12-20 15:20:31.353 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/systeme[0m
e[32m2024-12-20 15:20:31.357 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/systeme[0m
e[32m2024-12-20 15:20:31.361 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/systeme[0m
e[32m2024-12-20 15:20:31.364 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2024-12-20 15:20:31.368 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2024-12-20 15:20:33.679 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-12-20 15:20:33.681 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state runninge[0m
e[32m2024-12-20 15:20:33.683 INFO (MainThread) [supervisor.resolution.fixup] System autofix completee[0m
e[32m2024-12-20 15:21:29.856 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2024-12-20 15:43:20.950 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 15:43:21.222 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt-benutzer'e[0m
e[32m2024-12-20 15:48:30.073 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 15:48:30.968 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt-benutzer'e[0m
e[32m2024-12-20 15:51:49.139 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2024-12-20 16:10:25.331 INFO (MainThread) [supervisor.host.info] Updating local host informatione[0m
e[32m2024-12-20 16:10:28.591 INFO (MainThread) [supervisor.host.services] Updating service informatione[0m
e[32m2024-12-20 16:10:28.629 INFO (MainThread) [supervisor.host.network] Updating local network informatione[0m
e[32m2024-12-20 16:10:29.541 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio informatione[0m
e[32m2024-12-20 16:10:29.810 INFO (MainThread) [supervisor.host.manager] Host information reload completede[0m
e[32m2024-12-20 16:20:33.731 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state runninge[0m
e[32m2024-12-20 16:20:33.737 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisore[0m
e[32m2024-12-20 16:20:34.591 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/systeme[0m
e[32m2024-12-20 16:20:34.592 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/systeme[0m
e[32m2024-12-20 16:20:34.593 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addone[0m
e[32m2024-12-20 16:20:36.236 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/coree[0m
e[32m2024-12-20 16:20:36.239 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_servere[0m
e[32m2024-12-20 16:20:36.241 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_servere[0m
e[32m2024-12-20 16:20:36.243 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/systeme[0m
e[32m2024-12-20 16:20:36.245 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/systeme[0m
e[32m2024-12-20 16:20:36.246 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/systeme[0m
e[32m2024-12-20 16:20:36.252 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2024-12-20 16:20:36.253 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2024-12-20 16:20:38.251 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-12-20 16:20:38.253 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state runninge[0m
e[32m2024-12-20 16:20:38.254 INFO (MainThread) [supervisor.resolution.fixup] System autofix completee[0m
e[32m2024-12-20 16:22:28.996 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[31m2024-12-20 16:43:27.574 ERROR (MainThread) [supervisor.host.logs] Could not get a list of boot IDs from systemd-journal-gatewayde[0m
e[33m2024-12-20 16:46:16.376 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with core_mosquitto application!e[0m
e[32m2024-12-20 16:46:17.786 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 16:46:22.482 INFO (SyncWorker_6) [supervisor.docker.manager] Stopping addon_core_mosquitto applicatione[0m
e[32m2024-12-20 16:46:23.263 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 16:46:35.885 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 16:46:47.019 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt-benutzer'e[0m
e[32m2024-12-20 16:47:09.243 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt-benutzer'e[0m
e[32m2024-12-20 16:47:16.400 INFO (SyncWorker_6) [supervisor.docker.manager] Cleaning addon_core_mosquitto applicatione[0m
e[32m2024-12-20 16:47:52.682 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-mosquitto with version 6.4.1e[0m
e[32m2024-12-20 16:49:00.461 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 16:49:03.384 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt-benutzer'e[0m
e[32m2024-12-20 16:49:08.343 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 16:49:17.312 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 16:49:20.683 INFO (MainThread) [supervisor.auth] Home Assistant not running, checking cachee[0m
e[32m2024-12-20 16:49:22.291 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 16:49:31.017 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 16:49:32.560 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt-benutzer'e[0m
e[32m2024-12-20 16:49:36.406 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 16:49:42.799 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt-benutzer'e[0m
e[31m2024-12-20 16:49:53.851 ERROR (MainThread) [supervisor.services.modules.mqtt] There is already a MQTT service in use from core_mosquittoe[0m
e[32m2024-12-20 16:53:07.373 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2024-12-20 17:12:31.932 INFO (SyncWorker_3) [supervisor.docker.manager] Restarting homeassistante[0m
e[32m2024-12-20 17:13:29.811 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is readye[0m
e[32m2024-12-20 17:13:58.189 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2024-12-20 17:14:00.282 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)e[0m
e[32m2024-12-20 17:14:01.583 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-12-20 17:14:52.670 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='STARTING', offline_db_migration=False)e[0m
e[32m2024-12-20 17:14:57.861 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)e[0m
e[32m2024-12-20 17:14:57.862 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instancee[0m
e[32m2024-12-20 17:20:38.494 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state runninge[0m
e[32m2024-12-20 17:20:38.509 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisore[0m
e[32m2024-12-20 17:20:39.195 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/systeme[0m
e[32m2024-12-20 17:20:39.198 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/systeme[0m
e[32m2024-12-20 17:20:39.201 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addone[0m
e[32m2024-12-20 17:20:41.976 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/coree[0m
e[32m2024-12-20 17:20:41.006 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_servere[0m
e[32m2024-12-20 17:20:41.008 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_servere[0m
e[32m2024-12-20 17:20:41.010 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/systeme[0m
e[32m2024-12-20 17:20:41.037 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/systeme[0m
e[32m2024-12-20 17:20:41.047 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/systeme[0m
e[32m2024-12-20 17:20:41.068 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2024-12-20 17:20:41.069 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2024-12-20 17:20:46.416 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-12-20 17:20:46.419 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state runninge[0m
e[32m2024-12-20 17:20:46.422 INFO (MainThread) [supervisor.resolution.fixup] System autofix completee[0m
e[32m2024-12-20 17:23:27.406 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2024-12-20 17:23:52.480 INFO (SyncWorker_4) [supervisor.docker.manager] Restarting homeassistante[0m
e[32m2024-12-20 17:24:23.767 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is readye[0m
e[32m2024-12-20 17:24:57.722 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2024-12-20 17:24:59.393 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)e[0m
e[32m2024-12-20 17:25:01.934 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2024-12-20 17:25:47.076 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt-benutzer'e[0m
e[32m2024-12-20 17:25:47.147 INFO (MainThread) [supervisor.auth] Home Assistant not running, checking cachee[0m
e[32m2024-12-20 17:25:56.478 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)e[0m
e[32m2024-12-20 17:25:56.480 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instancee[0m
e[32m2024-12-20 17:28:29.032 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hacs/addons repositorye[0m
e[32m2024-12-20 17:28:29.097 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/music-assistant/home-assistant-addon repositorye[0m
e[32m2024-12-20 17:28:29.175 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/GollumDom/addon-repository repositorye[0m
e[32m2024-12-20 17:28:29.199 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repositorye[0m
e[32m2024-12-20 17:28:29.248 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repositorye[0m
e[32m2024-12-20 17:28:29.297 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repositorye[0m
e[32m2024-12-20 17:28:36.167 INFO (MainThread) [supervisor.store] Loading add-ons from store: 84 all - 0 new - 0 removee[0m
e[32m2024-12-20 17:28:36.168 INFO (MainThread) [supervisor.store] Loading add-ons from store: 84 all - 0 new - 0 removee[0m
e[32m2024-12-20 17:53:38.810 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
Those are the watchdog, but it has a lot more than that. What are all those POST errors?
I don’t know.
I made nothing with Post, nothing with superuser, my user is “mqtt-benutzer”
