I am using GoveetoMQTT to connect to two air purifiers and a humidifier. I am trying to use some cards I found for these devices, however, I am running into an issue where the sensor data displays {“value”:42} for the filter life percentage and {“value”:4} for the air quality. I am unsure how to extract the 42 to display on the card. I am pretty new to all this, so I apologize if it has been answered before or if this is a simple process. I wasn’t quite sure how to search for this specific instance.
Thank you!
Show us the full jason string then we be able to help you more
here this mite help
Where can I find that?
Find what ???
you need the topic path
also get MQTT Explorer that come your best friend
Thats what we want to see
- name: "Bla-Bla Its name"
state_topic: "copy the topic here that big long test bottom of page"
value_template: "{{value_json['value'] }}" #, <= think this is right
unit_of_measurement: ""
next you be asking where do i put
in the MQTT section under the sensors: bit
mqtt:
sensors:
not the spacing could be off
Thank you so much!
All good bro
MY BILL is you must help some else in here
