I’m at a loss - the payload looks like JSON.
Templating - Home Assistant clearly says value_json is available for MQTT payloads.
@123 can you take a look please?
It’s a Trigger-based Template Sensor so it will produce a trigger variable.
The trigger variable for an MQTT Trigger is documented here.
template:
- trigger:
- platform: mqtt
topic: v1/devices/me/telemetry
- name: ecs_cell_1
state: "{{ trigger.payload_json['cell1.Voltage'] if trigger.payload_json['cell1.Voltage'] is defined else this.state }}"
device_class: voltage
state_class: measurement
unique_id: ecs-bat-a4af5a96-02f6-418b-8e33-a80e7c7242b0
- name: ecs_cell_2
state: "{{ trigger.payload_json['cell2.Voltage'] if trigger.payload_json['cell2.Voltage'] is defined else this.state }}"
unique_id: ecs-bat-54fa7a4f-c7d6-47fc-80bb-0922fdbf8e97
It’s been my experience that if the received payload is normally in JSON format but on occasion it arrives not in JSON format, the template’s use of trigger.payload_json will produce an error. Hopefully this application doesn’t experience that problem with its payload format.
Urgh, I must have passed that section of the template sensor page loads of times.
Whenever the trigger fires, all related entities will re-render and it will have access to the trigger data in the templates.
Ah well.
now i get
Invalid config for ‘template’ at conf/ecs/escmqttneu.yaml, line 5: ‘sensor’ is an invalid option for ‘template’, check: sensor->0->sensor Invalid config for ‘template’ at conf/ecs/escmqttneu.yaml, line 5: required key ‘state’ not provided
Please post the full code, it’s probably an indentation issue.
looks ok in studio code
template:
- platform: mqtt
- name: ecs_cell_1
- name: ecs_cell_2
Now you can repeat for the rest of the Cells ![]()
yes - an temperature etc
once again thank you ![]()
