chabro
November 13, 2023, 3:21pm
1
i have a mqtt json array with topic
v1/devices/me/telemetry
wich holds Data from BMS System - i want to use
array looks
"cell16.Type": 101,
"cell16.Voltage": 3.226,
"cell16.Temperature": 9.1,
"cell16.lvp": 0,
"cell16.ovp": 0,
"cell16.bal": 0
the cell Number is from 1 to 16 within 1 or 2 seconds
i have a mqtt tool wich automaticall expand json array - there i get all separated Entries
in single topic but i can´t forward to home assitant
Template Editor shows the right value 3.166
{% set new_test = {"cell16.Type":101, "cell16.Voltage":3.166, "cell16.Temperature":8.4, "cell16.lvp":0, "cell16.ovp":0, "cell16.bal":0} %}
{{new_test["cell16.Voltage"]}}
if failed to extract this value from json
mqtt sensor:
- name: ecs_cell1_v
unique_id: ecs_cell1_v
state_topic: v1/devices/me/telemetry
value_template: "{{ value_json_cell16.Voltage }}"
i´ve already tried a lot of things and spent a lot of hours for solution
any help on this?
thank you
try:
value_template: "{{ value_json.cell16.Voltage }}"
dot instead of underscore between “json”
and “cell”
chabro
November 13, 2023, 3:53pm
3
no - won´t work - had that before
result unkown
armin-gh
(ArminH)
November 13, 2023, 4:13pm
4
Hmm…
value_template: "{{ value_json['cell16.Voltage'] }}"
chabro
November 13, 2023, 4:23pm
5
thank you - works
i get crazy i thought i test all possibilities
chabro
November 13, 2023, 4:31pm
6
additional questing
i didn´t get values from other cells aka cell1 through 15
cell16 is the last entry of that topic
it cycle through the entries very fast
the history of mqtt explores show the other values
chabro
November 15, 2023, 10:59am
7
i tested a little bit
when i listen within Home Assitant to that topic i get the following expanded json for 16 cells
here only 2 to shorten
Message 169 received on v1/devices/me/telemetry at 11:23:
"cell16.Type": 101,
"cell16.Voltage": 3.268,
"cell16.Temperature": 10.1,
"cell16.lvp": 0,
"cell16.ovp": 0,
"cell16.bal": 0
QoS: 0 - Retain: false
Message 168 received on v1/devices/me/telemetry at 11:23:
"cell15.Type": 101,
"cell15.Voltage": 3.266,
"cell15.Temperature": 11.9,
"cell15.lvp": 0,
"cell15.ovp": 0,
"cell15.bal": 0
Message 167 received on v1/devices/me/telemetry at 11:23:
but when i use the following code for extracting
- name: ecs_cell14_v
unique_id: ecs_cell14_v
value_template: "{{ value_json['cell14.Voltage'] }}"
- name: ecs_cell15_v
unique_id: ecs_cell15_v
value_template: "{{ value_json['cell15.Voltage'] }}"
- name: ecs_cell16_v
unique_id: ecs_cell16_v
i only get the last cell16 Value the other values are empty
any hints?
armin-gh
(ArminH)
November 15, 2023, 11:58am
8
the tool you mentioned in the initial message, can it provide the information for each cell in a different topic for HA? like
v1/devices/me/telemetry/cell1
v1/devices/me/telemetry/cell2
v1/devices/me/telemetry/cell16
chabro
November 15, 2023, 12:01pm
9
unfortunately no
but it should be possible to extract but i didn´t find the key
chabro
November 15, 2023, 2:23pm
10
for testing i increase the delay time between the 16 Entries
i can see the incoming values for each cell but with the next cell the before cell will be “”
@chabro Which tool are you using to expand the array?
template:
- platform: mqtt
- name: ecs_cell_1
state: "{{ json_value['cell1.Voltage'] if json_value['cell1.Voltage'] is defined else states('sensor.ecs_cell_1') }}"
device_class: voltage
state_class: measurement
unique_id: ecs-bat-a4af5a96-02f6-418b-8e33-a80e7c7242b0
- name: ecs_cell_2
state: "{{ json_value['cell2.Voltage'] if json_value['cell2.Voltage'] is defined else states('sensor.ecs_cell_2') }}"
unique_id: ecs-bat-54fa7a4f-c7d6-47fc-80bb-0922fdbf8e97
repeat for all 16
chabro
January 9, 2024, 5:29pm
13
sorry for the late answer didn´t see your answer earlier
wont´t work - i get unavailable
error log
Logger: homeassistant.helpers.sensor
Source: helpers/trigger_template_entity.py:208
First occurred: 18:10:34 (272 occurrences)
Last logged: 18:18:32
Error rendering state template for sensor.ecs_cell_1_voltage: UndefinedError: ‘json_value’ is undefined
Error rendering state template for sensor.ecs_cell_2_voltage: UndefinedError: ‘json_value’ is undefined
here output from “expanding tool”
thanks
chabro
January 9, 2024, 5:35pm
14
tool is maybe the wrong word
i have home automation system loxone and for this software enhancement loxberry
within loxberry there ist a mqtt plugin for access mqtt topic within loxone
in that plugin i can choose expand json wich shows me all expanded topics automatically without anything else todo
Sorry it’s value_json
not json_value
chabro
January 10, 2024, 12:13pm
16
thank you for the quick answer
still unavailable
Error rendering state template for sensor.ecs_cell_1: UndefinedError: ‘value_json’ is undefined
Error rendering state template for sensor.ecs_cell_2: UndefinedError: ‘value_json’ is undefined
Please post the full sensor code so we can see if there is anything else that needs fixing.
chabro
January 10, 2024, 10:14pm
18
template:
- platform: mqtt
- name: ecs_cell_1
state: "{{ value_json['cell1.Voltage'] if value_json['cell1.Voltage'] is defined else states('sensor.ecs_cell_1') }}"
- name: ecs_cell_2
state: "{{ value_json['cell2.Voltage'] if value_json['cell2.Voltage'] is defined else states('sensor.ecs_cell_2') }}"
i´ve made copy / paste from your code
OK, we are really going to need a raw MQTT packet, because the error value_json is undefined, suggests that the data that was received was not JSON - ie it could not be decoded to a JSON object.
I don’t have any experience with “the expanding tool” I don’t know what that is, but it looks like the path is actually v1/devices/me/telemetry/cell1
or possibly v1_devices_me_telemetry_cell1
EDIT:
If you use a tool like MQTT Explorer - we might be able to better understand what is going on.
chabro
January 11, 2024, 7:03pm
20
in mqtt explorer i see json format
in HA MQTT listen to topic i see
the json entries(16) come in within a few seconds with the same topic v1/devices/me/telemetry
i think the other tool make a kind of caching ?!?
