I’m using a docker that publishes a JSON by MQTT (dwinks/pwrstat_docker)
{"Model Name": "CP900EPFCLCD", "Firmware Number": "000000000000", "Rating Voltage": "230 V", "Rating Power": "540 Watt", "State": "Normal", "Power Supply by": "Utility Power", "Utility Voltage": "242 V", "Output Voltage": "242 V", "Battery Capacity": "100 %", "Remaining Runtime": "78 min", "Load ": "27 Watt(5 %)", "Line Interaction": "None", "Test Result": "Unknown", "Last Power Event": "None"}
- name: Cyberpower-Model Name
state_topic: "sensors/basement/power/ups"
value_template: "{{ value_json['Model Name'] }}"
qos: 0
- name: Cyberpower-State
value_template: "{{ value_json['State'] }}"
qos: 0
- name: Cyberpower-Output Voltage
value_template: "{{ value_json['Output Voltage'] }}"
qos: 0
- name: Cyberpower-Battery Capacity
value_template: "{{ value_json['Battery Capacity'] }}"
qos: 0
- name: Cyberpower-Remaining Runtime
value_template: "{{ value_json['Remaining Runtime'] }}"
qos: 0
- name: Cyberpower-Load
value_template: "{{ value_json['Load'] }}"
But it happens that when I click on the entity, only state changes appear
I already added “unit_of_measurement” the entity becomes unavailable
what could i be doing wrong?
I wanted to get something like this
