MQTT Sensor: How to create a sensor for STV MPW32-IP Messages?
Hi Community
I have a MBUS-MQTT-Gateway from STV electronics (MPW32-IP) that receives data from 4 MBUS devices and sends them as MQTT messages to home assistant. I can see the messages in MQTT Explorer. These have the following scheme (The data_records section is shortened and only 2 of 4 devices are shown).
Can you help to create an configuration for an mqtt-sensor?
 "primary_address": 1,
 "secondary_address": "06365066",
 "manufacturer": "SEC",
 "medium": "Electricity",
 "data_records": [
   "unit": "Manufacturer (as in fixed header)",
   "value": "Schneider Electric"
   "unit": "Model / Version",
   "value": "iEM3135 "
   "unit": "Firmware version",
   "value": "1.4.002"
   "unit": "Error flags",
   "value": "64"
   "unit": "Current (A)",
   "value": "2.105615"
   "value": "1.316972"
 "primary_address": 2,
 "secondary_address": "71494503",
 "manufacturer": "KAM",
 "medium": "Heat: Outlet",
 "data_records": [
   "unit": "Energy (kWh)",
   "value": "49077"
   "unit": "Manufacturer specific",
   "value": "477854"
   "value": "436544"
   "unit": "Volume (1e-2  m^3)",
   "value": "1460506"
thanks in advance for your answer and help
yeaahh, i find the solution. I’m sharing the solution in case others can use it:
template:
  - trigger:
      - trigger: mqtt
        topic: /8C1F6437CC95/mbus
        value_template: "{{ value_json.primary_address }}"
        payload: 1
      - name: "Elektrizität (Energie)"
        unique_id: "electricity_energy"
        state: "{{ trigger.payload_json.data_records[24].value |float / 1000 }}"
        state_class: Total
        device_class: ENERGY
        unit_of_measurement: "kWh"
        attributes:
          data_records: "{{ trigger.payload_json.data_records }}"
  - trigger:
      - trigger: mqtt
        payload: 2
      - name: "Wärme (Energie)"
        unique_id: "heat_energy"
        state: "{{ trigger.payload_json.data_records[0].value }}"
        state_class: Total
        attributes:
      - name: "Wärme (Temperatur Vorlauf)"
        unique_id: "heat_temperature_in"
        state: "{{ trigger.payload_json.data_records[8].value |float / 100}}"
        device_class: TEMPERATURE
        unit_of_measurement: "°C"
        attributes:
      - name: "Wärme (Temperatur Rücklauf)"
        unique_id: "heat_temperature_out"
        state: "{{ trigger.payload_json.data_records[9].value |float / 100}}"
        attributes:
  - trigger:
      - trigger: mqtt
        payload: 3
      - name: "Warmwasser (Volumen)"
        unique_id: "water_hotwater_volume"
        state: "{{ trigger.payload_json.data_records[1].value |float / 10000}}"
        state_class: Total
        device_class: WATER
        unit_of_measurement: "m³"
        attributes:
  - trigger:
      - trigger: mqtt
        payload: 5
      - name: "Kaltwasser (Volumen)"
        unique_id: "water_coldwater_volume"
        state_class: Total
        device_class: WATER
        attributes:
