I’m trying to add last_reset to my mqtt sensor, but I always get invalid configuration. 2 examples at the bottom have been commented out with #, if I remove any I get invalid configuration
- platform: mqtt
name: "Mains Consumed Energy"
state_topic: "electricity1/tele/RESULT"
value_template: >-
{% set message = value_json.SerialReceived %}
{% set payload = message[6:14] %}
{% set payload_len = (payload | length) %}
{% set result = namespace(value='') %}
{% for i in range(0, payload_len + 1) | reverse -%}
{%- if i is divisibleby 2 -%}
{%- set result.value = result.value + payload[i:i+2] -%}
{%- endif -%}
{%- endfor -%}
{{ (result.value|float) / 100 }}
unit_of_measurement: 'kWh'
unique_id: "mains_consumed_energy"
device_class: energy
state_class: measurement
# last_reset_value_template: {{ '1970-01-01T00:00:00+00:00' }}
# last_reset_value_template: {{ as_datetime(as_datetime(0|timestamp_utc)|string+‘Z’).isoformat() }}
I will be doing the same thing (haven’t yet)…Here is a thread that discusses a couple of ways to do this:
Use homeassistant: customize instead of the mqtt sensor config
Use mqtt sensor config as you have attempted and set up a “fake” last_reset_topic and somehow publish a retained message to that topic with a message containing a reset time
Question: can the last_reset_topic_template option work without using the last_reset_topic option?
It seems to me it was designed to be used to extract a value from the topic’s payload. However, if used alone, maybe the topic’s payload is not needed?
Asking because there’s no last_reset_topic in the first post.
I haven’t found a single last_reset_value_template to work at all, but confess only tried them stand alone, without a last_reset_topic to extract data from.
I did, as described above, found a way to use the topic, standalone that is.
This all is of course for the never reset scenario, and doesn’t follow any devices reset, which isn’t supported in my devices to begin with.
the beauty of Pluto’s config is it seems to do just that.
I think the reason why this doesn’t work is because it won’t evaluate the template until a payload is received. However, the purpose of this approach is to avoid having to publish anything to the topic so it’s a stalemate.
My config without the last_reset_topic doesn’t work.
I suppose that it works just like the value_template that is taken from the state_topic… So the last_reset_value_template is taken from the last_reset_topic
not sure if I expressed myself clearly, but using the single last_reset_topic works fine (provided the once in a life time retained publish I screenshotted…)
yes that seems to be the final conclusion, and I think that should be indicated in the docs more clearly.
You can use a last_rest_topic on its own, provided it is of the correct format already. If not and one needs to extract data, use the additional last_reset_value_template
Yes, I understand that particular approach works for the simple reason that it complies with the intended purpose of last_reset_topic.
My comment was targeted at the other approach you appear to have attempted in the past where you hard-coded the Unix Epoch into last_reset_value_template. The assumption is you did that to avoid having to explicitly publish that value. However, it fails because the template is not evaluated until a payload (any payload) is received via last_reset_topic.
correct. I did try that, because Frenck insisted ‘it’ should work. He didnt however say we need the last_rest_topic first…
Ive asked in Discord #devs_energy now, so hope we can get confirmation our conclusion is in fact correct
It’s also more specific than the description for plain old value_template
Defines a template to extract the value
That’s why I was puzzled by the lack of the last_reset_topic option in the first post. The combination of topic and corresponding value_template is fairly common (json_attributes_topic and json_attributes_template) so seeing last_reset_value_template used alone seemed anomalous to me.
with that knowledge Frencks answer makes sense now. At the time of that post, some of us were in the effort trying to make that stand alone template work, not thinking past our own mind lock…
It uses the same topic for state_topic, json_attributes_topic, andlast_reset_topic.
Because state_topic will regularly receive payloads, it will cause last_reset_value_template to be evaluated the moment a payload is received via the shared topic.
The actual content of the payload is irrelevant for last_reset_value_template because it doesn't use it and is hard-coded with the Unix Epoch.
Applying this simple principle to Marius' example, we get this:
but just didnt think of that. also because state_class: measurement isn’t supported on those legacy template sensors.
however, and this is HUGE news, with 2021.8.2 we can now use the template: in packages, and that is enough reason to spend the rest of my holidays rebuilding the template sensors in my config
I’m very new to MQTT and frankly almost all of this has gone entirely over my head…
I’m installing a Shelly EM tomorrow and was hoping to use it with MQTT (this was my plan before 2021.8 so it’s a really well timed update for me)!
Not a damn clue how to set it all up… why are there two sensors and more importantly are they both template sensors or what? I get the MQTT sensor but what the heck is the bit that Taras named ZP Import?
